The Road Rider Returns
Results 1 to 2 of 2
Like Tree8Likes
  • 7 Post By dogonit
  • 1 Post By SimpleScout
Thread: The Road Rider Returns
    Senior Member dogonit's Avatar
    Aug 2014
    south central Va.
    656
    Hi guys: It's been a long time but i thought I'd get back to the forum for a moment to let those few outliers like myself that use this wonderful off road bike as a true road runner. What you need to do if that is your crazy unreasonable desire is first to re-jet the carbs. Then to get a 15T front sproket and then work around the other things. I personally think that Hi-rise bars are way better for your back and a good seat replacement is in order. You need a more road type tire, I have run the 203/204's which are fine though I am now running the Shinkos. Run the tires at higher pressure 25 back and 22 front if you are planning on running above 55 or 60 for any regular times. I run Mobil one oil and different air filters from stock. I have also added things which i feel are advantageous to the ride. I have welded longer not wider foot extensions for comfort and also additional extensions to the foot brake. I have changed the shift lever just because I liked it better and I have a DG muffler, while loud(wear ear plugs), I do believe does give some extra aspiration to the whole deal. That I am sure will get more than a bit of comment. Whatever blows her shirt up. I can and do regularly run at or about 60(65+) on my odometer for relatively long periods on occasion. Most of my running is back country paved roads that I usually run around 45-60 on the odometer. Use regular non-ethanol gas if at all possible. I have some extra brackets that i use for carrying things. The cycle rack that i had was more than I needed and replaced that long ago. Well enjoy and it is true that a few weird individuals actually use this bike as a roadster. Join the party.DSCN1096.JPGDSCN1010.JPG
    Just give me a minute while I collect my thoughts. They're around here somewhere. Maybe!
    2013 TW200(Protaper SE ATV High handlebars, DID 428VX-X ring chain, Shinko Tires, K&N Air Filter, Seat Concepts "Grip" seat covering, Outlaw Racing Folding
    Gear shifter, My custom( long/thin) foot pegs, My custom(extended) Rear brake lever, Battery tender harness, Gel Battery, "Bikini" Bike rack, Mobil 1 4T synthetic, BLUE Ricochet Skid Plate , DG Exhaust & 15 Front Sproket.
    Junior Member SimpleScout's Avatar
    Dec 2018
    Fort Collins, CO
    19
    Thanks for sharing! Sharp looking setup
    jtomelliott49 likes this.
  1. FB Mondial returns
    By Rockit in forum Other Bikes
    Last Post: 09-30-2016, 10:45 PM
  2. Honda's legendary Africa Twin returns.
    By littletommy in forum Other Bikes
    Last Post: 08-02-2015, 07:24 AM
  3. Old Timer Returns
    By OldLazyDog in forum General Discussion
    Last Post: 03-19-2015, 12:22 PM
  4. Chain Gang Returns to Mineral
    By admiral in forum Trails, Off-road, and Adventure Riding
    Last Post: 02-09-2012, 09:33 AM
  5. Off road rack by Rough & Road
    By Mame Shiba in forum Performance and Customization
    Last Post: 04-10-2011, 01:03 PM
