Frame touch-up vs. Complete redo
Results 1 to 10 of 18
Like Tree25Likes
Thread: Frame touch-up vs. Complete redo
    Senior Member YBW's Avatar
    Jul 2016
    Buena Vista, VA
    249
    My '99 is starting to show its age and coastal use almost exclusively around the welds where paint is bubbling and/or flaked off.
    I initially planned on tearing it down and doing a complete cosmetic refresh but since its great mechanically and the the only real cosmetic issues are the aforementioned welds (which I'm worried may become structural if not addressed), I'm thinking about just addressing the problem areas.
    Has anyone else done this? If so what were the results? What paint did you use (I would prefer it to match the factory)? Thanks!
    Smitty Blackstone likes this.
    Mar 2015
    Ynys Môn
    4,494
    Chain lube - gets into where paint doesn't - repeat each year ......
    Darth and Smitty Blackstone like this.
    - Hidden Content
    Senior Member Old n dirty's Avatar
    Aug 2017
    Southern California
    149
    If you don't need to tear it down don't do it!
    One of mine that only needed cosmetic touches is still sitting because it's easier to just ride something else and time is always short. Ride, ride, ride.
    You'll never see a motorcycle parked in front of a psychiatrist office!
    Theirs a ass for every seat!
    Tennessee
    1,280
    I'd touch it up, maybe with POR15 or something like that. I wouldn't disassemble unless I knew I wouldn't be riding or had something else to ride, plus the time, space, and all the little things you might wanna replace as you reassemble.
    Apr 2013
    385
    if you tear it down you will end up doing far more work than you thought or planned to, personally i'd remove cables, panels, lights and just spend time masking off the bits you don't want painted.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    7,925
    I am in the process of rebuilding a 1987 BW350 that was also showing some age at the welds but was otherwise in real nice shape. I removed a red painted part from the frame and took it to the Auto paint store. They have a machine I will call a paint color photographic analyzer and they took a picture which ran through the computer. Then he was able to mix the color and put it into 2 rattle cans. It cost me $30 for the works but the color match is as near perfect as I could ever hope for and it also takes into account the age fade of the original red. The rest of the process is an art in itself where taping off all the parts you don't want over spray to show on. Again, the automotive paint store has just the right tapes and papers for this. I still have to now reverse the process and tape off all the fresh painted red parts so I can do the black on the engine. It is a toss up as to weather it is easier to tear the bike down to the frame to do it right or to spend the hours taping and spraying things in place. Properly prepping the welds before paint is a major key to getting it to look good and last. I used a couple different wire wheels on drills and a dremel tool to clean all the rust and crud off and then used Prep Sol before I painted. With automotive paint I am pretty confident it will last but with off the shelf spray paints I have had less than great results. I did have a set of aluminum car wheels powder coated a few years ago and was very impressed with the results but that was a rather painless thing to have done except for the cost.
    1987 Yamaha BW350 Big Wheel
    Feb 2017
    Waretown NJ
    538
    Try PJ1 spray paint .Great to work with. PJ1 make paints with many factory colors. If you have the time tear it down and paint. the 200 is an easy bike to wirk on.
    Powder Coat is the best.I did my mx bike frame.Still looks new.
    87 TW
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,468
    One little trick I noticed the painters at work doing is using aluminum foil for masking . Much easier to use because it keeps its shape.
    GaryL, Smitty Blackstone and Darth like this.
    Jun 2013
    Forestburgh, NY
    7,925
    Quote Originally Posted by Peterb View Post
    Great info Pete! The tin will form around the tight spots way better than the paper and tape I used and probably easier to form around stuff. Pretty expensive though but time is money so I will use that trick myself when I do my engine. I bet I spent a few hours just covering all the stuff I did not want paint over spray on so anything that makes the job easier and less time consuming is fine by me. Color matching is the most important part of doing half a job on frame paint once you cover the parts that you don't want over spray on but it can be done with great results. The frame up and under my fuel tank was still original and bright red but the rest had some fade in it and the automotive photo analyzer got that about as close as I ever expected it would. Red is a rather tough color while black and blue frames may not be so critical.
    Feb 2017
    Waretown NJ
    538
    It's too late into the season now.But I wish I powder coated my frame
    87 TW
  1. TURTLEPALOOZA ReDo, Redieu, Redux? July 2, 2016
    By jbfla in forum Trails, Off-road, and Adventure Riding
    Last Post: 07-07-2016, 08:21 AM
  2. Booze is the only thing I'm qualified to touch
    By dabsdog in forum General Discussion
    Last Post: 04-19-2015, 03:44 PM
  3. Replies: 49
    Last Post: 11-06-2014, 12:31 PM
  4. Should my gas tank be hot to touch at idle???
    By iamclosetgeek in forum Technical Help
    Last Post: 06-04-2014, 08:51 PM
  5. Decided to add a personal touch to the tdub...
    By OSOK in forum Performance and Customization
    Last Post: 09-06-2013, 03:33 PM
