Hand guard installation
Results 1 to 5 of 5
Like Tree7Likes
  • 1 Post By ashleyidesign
  • 1 Post By NorthernSpy
  • 2 Post By TW-Brian
  • 1 Post By fagro
  • 2 Post By stagewex
Thread: Hand guard installation
    Junior Member ashleyidesign's Avatar
    Feb 2019
    Salem, MA
    20
    Trying to install hand guards and the cross bar on the stock bars is interfering with the Acerbis mount. Anyone have recommendations on different guards that work with the stock bars? I trimmed the end of the throttle tube but still get interference with the throttle so I took everything off for now.
    Sent from my Pixel 2 using Tapatalk
    jtomelliott49 likes this.
    Ashley
    Salem, MA (for now)
    - '19 TW 200 🏍️
    - '17 VW GLI 🚗
    - '86 Int'l S1753 🚌
    Senior Member NorthernSpy's Avatar
    Mar 2018
    Powell River, BC
    115
    I was able to get Barkbusters on with little problem. Pretty heavy duty too.IMG_20180929_150603 (1).jpg
    Pleasanton, CA
    5,635
    The Tusk D-Flex Pro handguards fit with the stock TW handlebars.
    Are you sure that the Acerbis guards are a no-go? All universal type handguards are a bit finicky and may require some persuasion (i.e., bending) to get the mounts fitted.
    Junior Member fagro's Avatar
    Mar 2019
    19
    I was having trouble with the clamp hitting the crossbar with a Cycra knockoff set of hand guards. I was able to put the hand guards in a vice and bend them in to "elongate" them and it worked.
    As far as the throttle tube goes..
    Just have to trim it flush with the handlebar end, the slide the whole throttle assembly inboard. Be aware that the throttle clamp has a plastic "tit" that goes in a hole in the bars. You will have to either remove the "tit" or drill another hole in the bars in order to move assembly inboard.
    Jun 2016
    New Rochelle, New York
    1,711
    Tusk (of course).
    But the ones you have should fit. You do have to do a bunch of bending and moving stuff around. These are all generic and are supposed to fit a variety of bikes.
    1995 BMW K75 (Elec Start)
  1. Cheap hand guard question.
    By Padilen in forum General Discussion
    Last Post: 08-21-2014, 10:48 AM
  2. Hand guard help
    By keithmaine in forum Performance and Customization
    Last Post: 06-17-2014, 06:27 PM
  3. Please Help with hand guard install
    By Holdnon72 in forum Technical Help
    Last Post: 02-15-2014, 06:19 PM
  4. Chain Seal, Guard installation
    By mkriley in forum Technical Help
    Last Post: 05-26-2013, 11:00 PM
  5. Chain Seal, Guard installation
    By mkriley in forum Technical Write-Ups
