Gearing for ATV tire
Results 1 to 3 of 3
    Senior Member flyhunter3825's Avatar
    Nov 2012
    DePere, Wisconsin
    296
    For those of you running an ATV tire, what gearing did you go with if you didnt go with stock? What works best? Ive got the Ceros but im waiting for the wheels to get back from the powder coater to mount it.
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    It really depends on what kind of riding you do, and where you are on your chain and sprockets. I wouldn't necessarily run out and buy new chain and sprockets unless they're ready to be replaced. I also have the Ceros and have been running around for the last year or so on stock gearing. The low first gear is still low enough for most of what I do. If you are ready to replace your chain and sprockets I think you would be happy with a 55 tooth sprocket, unless you spend a lot of time on the open road. That'll put you back to just a little deeper than stock. You can put in the actual size of the Ceros in the sprocket calculator found here and play with it a little bit. The OD of the Ceros is found in this thread.
    Senior Member FootDoc's Avatar
    NYC
    196
    Quote Originally Posted by B-dub View Post
    I also have a Ceros and run a 55t out back.
    Its a good compromise, 1st is pretty low with enough legs for short highway trips.
    Until I picked up a nail last month, I was bombing around town. For an atv tire I think the Ceros handles well.
    2002 TW200
    2003 TW200
    2002 Mean Streak
    2002 Speed Four
    2006 FZ6
    1999 Jog
  1. Road trip gearing
    Last Post: 07-25-2012, 08:45 PM
  2. Gearing change
    By [email protected] in forum General Discussion
    Last Post: 04-27-2012, 02:24 PM
  3. My First TW, Accessories and Gearing etc?
    By JayinMaine in forum General Discussion
    Last Post: 03-10-2012, 09:37 AM
  4. Best way to change gearing
    By sherm in forum Technical Help
    Last Post: 04-11-2011, 06:30 PM
  5. Gearing different between 2000 and 2008 models?
    By kiloforce in forum General Discussion
    Last Post: 08-12-2010, 07:58 AM
