Chain slider for the frugal
Results 1 to 6 of 6
Like Tree11Likes
  • 8 Post By ScottRod
  • 1 Post By BrotherJim
  • 1 Post By Apolloha
  • 1 Post By Maxpower
Thread: Chain slider for the frugal
    Junior Member ScottRod's Avatar
    May 2019
    Warsaw, IN
    4
    Ok, well I'm new here, but I just recently bought my first TW.
    In going thru and fixing this and that, I decided I needed a new tube in the rear, and while I was at it, I figured I might as
    well paint the wheel and swingarm. Anyway, my chain slider was falling apart and oddly enough, there isn't much info here
    or other places on the internet to get an inexpensive replacement. There was no way this cheapo was going to pay $37 for
    one and have to wait 'till it arrives from China.
    Being a machinist, I was going to use a piece of UHMP poly and make one, but I decided to go even cheaper and easier.
    Attached are the pictures. Basically, I just used a 18" strip of 1/4" x 2" white teflon, wrapped it tightly around the swingarm,
    pop riveted it in place.
    Installed a new chain and slapped it all back together. So far it is running quiet and smooth. We'll see how long it lasts.IMG_20190521_162410531.jpgIMG_20190522_200551541.jpg
    Fred, Sthrnromr, TW-Brian and 5 others like this.
    ScottRod
    ScottRod Customs, LLC
    Christian Motorcyclists Assoc. State Area Rep
    2015 H-D FLTR, 2018 Scout, 1978 XS650, 1986 Radian, 1986 Fazer, 1990 TW200 Hidden Content , 1986 Honda TLR200 Reflex
    Junior Member BrotherJim's Avatar
    Jan 2019
    East Central Indiana
    11
    Nice work!
    jtomelliott49 likes this.
    Senior Member Apolloha's Avatar
    Dec 2018
    113
    Good idea. I like it!
    2017 Apollo 250
    2018 Yamaha TW200
    1978 Suzuki DR370
    Feb 2017
    Waretown NJ
    485
    You pop riveted it directly to the swing arm?
    I made one from a rubber mat I took from the dumpster on the job. I mounted mine the same way the original was. I had cut a block or Teflon or plastic decking (I don't recall ) and fitted it to recreate the stock set up.
    I wouldn't call you frugal. 37 dollars is alot for that part. I wonder why they are so costly?
    I would think that they would be less as it's the same for every TW ever made
    87 TW
    "The nine most terrifying words in the English language are : lm from the government and Im here to help" - Ronald Reagan
    Sep 2012
    Wichita, KS
    1,849
    Nice work. I would be proud to hang out with another "Cheapo". I love it when someone does this kind of innovation.
    Tom in Wichita
    78 Moto Guzzi SP1000
    87 Yamaha TW200
    99 Yamaha TW200
    May 2019
    Warsaw, IN
    4
    Yes, drilled right into the swingarm. It's mainly just stamped steel anyway. 1/8" rivets
    ScottRod
  1. Clutch arm return spring and chain slider.
    By Canoeman in forum Technical Help
    Last Post: 04-07-2019, 09:12 PM
  2. Cleaned up my swingarm during chain slider replacement
    By spewingjason in forum Performance and Customization
    Last Post: 01-17-2018, 08:20 PM
  3. Chain Slider/Guard
    By indika666 in forum Technical Help
    Last Post: 03-12-2017, 08:10 PM
  4. YZ85 chain Slider install
    By Sathump in forum Performance and Customization
    Last Post: 06-22-2016, 06:37 AM
  5. slider extenstions for TW200's ?
    By flw in forum Performance and Customization
    Last Post: 07-27-2011, 05:54 PM
