Aftermarket foot pegs
Results 1 to 10 of 16
Like Tree20Likes
Thread: Aftermarket foot pegs
    Junior Member Dozerash's Avatar
    Oct 2018
    25
    I bought aftermarket foot pegs for my 09 TW from Amazon, they look decent for the price. But I guess I need to drill a hole somewhere for the new pegs? There isn’t any directions. I haven’t had time to figure it out yet. Anyone use these before?
    Foot Peg Rearset Fits Yamaha... https://www.amazon.com/dp/B07Q81RSHN...p_mob_ap_share
    jtomelliott49 likes this.
    Senior Member Miaugi's Avatar
    Oct 2017
    Alfred, On
    462
    Hi Dozerash, these are meant to replace the original footpegs which are very skinny/small for most riders. Personally I found the easiest way is to remove the entire bracket holding the footpegs onto the bike. If you are sitting on the bike the right side has 2 bolts with a Allen key head and the left side has 1 bolt with a standard 6 point head. Of course everything on the bike is metric although sometimes you can get SAE tools to work but I suggest the proper metric size tools would be better for you. After you remove the brackets it helps if you have a bench vise to hold the brackets. For disassembly you remove the cotter pin and then slide out the shaft holding the footpeg to the bracket. Take note of how the spring is set-up and to reinstall I had to use a awl to line the spring up to reinsert the pin into the assembly. I also rounded off the pin on a grinder to allow it to be easier to install. It may sound complicated but it is not. Try one side first and see how it goes. Good luck!
    Donzo, jtomelliott49, Fred and 1 others like this.
    Oct 2018
    Rural, South Carolina
    578
    2010 TW200 - The Goat
    Triumphs
    ATVs
    Oct 2018
    25
    The problem is the aftermarket foot peg springs mount totally different than the stock ones. I tried mounting them the pegs fit nicely but the springs bind up and won’t let the pegs fold down properly.
    Oct 2018
    578
    Quote Originally Posted by Dozerash View Post
    Correct. See my post above for the adapter mounts.
    Triumphs
    ATVs
    Junior Member Krakrak's Avatar
    Apr 2019
    Laval, Quebec, Canada
    19
    I just bought in installed the same footpegs (but from Amazon.ca): https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
    I read about the problem with the hole for the spring, but it seems they read the reviews because those I received already had 2 holes on one of the pegs. I installed them yesterday and they went in like a charm. I should have taken a photo before...
    I don't know if the manufacturer dit the modification or if it's the vendor. Maybe that's why they're more expensive from this vendor?
    Edit: after comparing the pictures they're not the same I think.
    Miaugi likes this.
    Hailey, ID
    3,229
    If they are like the ones I got, you only have to drill a hole in the right hand one....or is it the left? It's not difficult to suss out if you do one side at a time.
    Admannnnnn likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Hailey, ID
    3,229
    Quote Originally Posted by Krakrak View Post
    ....Maybe that's why they're more expensive from this vendor?.....
    Probably because the metal is better quality. The hole is worth about $1 of shop time. Those are the ones I would get next time.
    1 Bad dog likes this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member Darth's Avatar
    Nov 2013
    Timbercreek Canyon, Texas
    1,581
    Anybody have any experience with these ProCycle foot peg doobies?
    They weld onto the stock footpegs and add 1/2 inch, length & width.
    I like small(er) pegs and these look about right.
    Any issues?
    Still, I rise!
    Humans: simultaneously capable of such genius and such douchebaggery!
    "Give a Damn"
    - C. M. Howe, Jr.
    RDW
    RDW is offline
    Senior Member RDW's Avatar
    Nov 2013
    Oregon
    172
    Quote Originally Posted by Darth View Post
    Any issues?
    I installed a set of these. No complaints, they work fine.
    Sthrnromr and Darth like this.
    2013 TW200---2007 XT225---2014 CB500X
  1. Wanted-rear Foot Pegs Passenger pegs
    By eddy in forum TW200 Classifieds
    Last Post: 07-15-2018, 03:05 PM
  2. Oversized foot pegs from eBay / China
    By mudpuppy in forum Performance and Customization
    Last Post: 04-24-2012, 04:13 PM
  3. Upgraded foot pegs
    By gskeem in forum General Discussion
    Last Post: 01-29-2011, 09:10 PM
  4. Foot Pegs E-bay
    By carmwes in forum TW200 Classifieds
    Last Post: 01-18-2011, 08:08 PM
  5. wide Black Steel foot pegs available again
    Last Post: 01-01-2011, 08:03 AM
