Filament vs HID vs LED headlights .... - Page 2
View Poll Results: Choose an option ...
Voters
41. This poll is closed
  • Im happy with filament bulbs
    6 14.63%
  • Im happy with my HID
    0 0%
  • Id be happier with an LED
    14 34.15%
  • I have an LED (and Im happy with it)
    15 36.59%
  • Im just happy, and youre talking bollox
    6 14.63%
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Like Tree20Likes
Thread: Filament vs HID vs LED headlights ....
  1. #11
    Mar 2015
    Ynys Mn
    4,475
    A couple of questions for the JNS users:
    Is it adjustable up and down
    Is it adjustable left and right
    Is the reflector biased left or right – or is the beam centred “straight ahead” ?
    jtstdub likes this.
    - Hidden Content
  2. #12
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,351
    don't they have that on their website?
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
  3. #13
    Mar 2015
    Ynys Mn
    4,475
    Nope ....
    - Hidden Content
  5. #14
    Member Willys714's Avatar
    Feb 2012
    68
    A bright headlight is a good start, but You really want/ need a helmet light for any night riding.
    Wherever you look is lit up and this kills the tunnel vision created by the headlight. It fills in the dark spots And let’s you see down offshoots of the trail.
    Trailtech had dual hid’s which were amazing but I cheaped out and use a bike halogen with a water bottle shaped battery. The trailtech hid’s are so bright I just follow my buddy closely. The halogen is more like a flashlight compared to the hid’s but it is self contained and works off bike, which is hugely handy. I have found It doesn’t take a lot of lumens if it’s focused where you’re looking.
    If you do run a helmet light you need to learn to look away from oncoming traffic and hikers who step off trail, I still forget but am usually quickly reminded.
    ejfranz likes this.
  6. #15
    Member JNS Engineering's Avatar
    Feb 2016
    59
    Yes, it’s adjustable up and down.
    The low beam pattern cut-off is flat and symmetrical left to right. No bias and no need for left to right adjustment.
    The JNS headlight aim on the attached photo is a bit higher but you should be able to appreciate the difference in light output and pattern width.
    Purple, Sthrnromr and jtstdub like this.
    Premium Dual-Sport Accessories
  7. #16
    Mar 2015
    Ynys Mn
    4,475
    Thanks for the reply ...
    - Hidden Content
  8. #17
    Feb 2015
    Maple Ridge, BC, Canada
    1,507
    I need another category: I am too old to ride trails at night (it's hard enough in daylight)
    I try not to ride at night and it would be nice to have a better headlight. That being said, If you are really serious about trail riding at night you need a good helmet mounted light.
  9. #18
    Jan 2015
    Fair Oaks, Calif
    496
    Another question to JNS... Is there any regulation for the light?
    The biggest led failure for home, auto and rv interior lights is the CHEAP electronics used to regulate, drop down the voltage to keep the LED's operating within there fairly narrow current/voltage specs.. Push them too bright and the life expectancy is from a few hours to a few hundreds, not the 10,000 hrs led's are expected to live.
    Jim
  10. #19
    18,418
    I've been having pleasant results with simple ~$20 plug & play H4 bulbs as long as they have three emmitter faces on seperate pylons. Ones like these current offerings:
    [Sponsored]Auxbeam LED Headlight Bulbs F-S2 Series LED Headlights with 2 Pcs of H4 LEDConversion Kits72W 8000lm Hi-Lo Beam
    I back them up with another ~$20 of spot beams like these, they bold directly to forks w/o need for any adaptors or brackets:
    2 of WEISIJI 20W 4 Inch Daytime Running Lights 4D Lens Spot Beam Led Work Light Bar for Cars/Jeep Wrangler/4x4-Jeep Cabin/UTE/SUV/ATV/Truck/Car/Boat/Fishing (2PCS)
    They create lighting like this but usually I aim the spot lights much further down the trail:
    An alleged total of about 7500 lumens. The spots usually cast noticeably bright pools of light on upcoming tree trunks during daylight if in the shade. Total combined draw is about same 55 watts as single oem H4 bulb.
    2006 TW200 "Nibbler", a.k.a. Mr.Gizmo"
    Hidden Content All Things Considered Ild Rather Be Motorcycling
  11. #20
    18,418
    If anyone wants H4 HIDs I have a pair with HID low beam and Halogen high beam plug-n-play H4 bulbs for a nominal contribution. PM me. Low beam seems way too bright for street use, I took them out of a truck but they should fit in a TW if you can hide the ballast.
