Gas Tank mod?
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By Gastone165
Thread: Gas Tank mod?
    Junior Member BikeNbowHNTR's Avatar
    Jan 2018
    Vancouver Island
    18
    Gas Tank mod?
    Any thoughts on putting this on the TW? The price is right and it’s a beast! 3.2 gallons I think. I have a second seat and a second set of plastic if I need to mod heavily. It’s off a 2008 KTM250. Apparently it is a safari?
    2009 TW200, stock, so far...
    Oct 2018
    Rural, South Carolina
    630
    Gas Tank mod?
    You may be able to “make it fit” with some creative modifications and mounting but I would say it’s not likely otherwise. Now I cannot see the underside to verify mounting but that’s just my best guess from what I can see. Have a look at the XT225 tanks, either stock or Clarke. I mounted one and like it so far.
    2010 TW200 - The Goat
    Triumphs
    ATVs
    Dec 2017
    Western Washington
    203
    Quote Originally Posted by Sthrnromr View Post
    Sthrnromr, how did the TW side panels line up with your Clarke XT225 tank? In the photo you posted they look good.
    Thanks!
    elBuro likes this.
    1972 Yamaha DT 175, 1974 Kawasaki 125, 1976 Suzuki TM 250, 1979 Yamaha 750, 1977 Husquvarna 360, 1979 Husquvarna 250, (2) 1980 Suzuki RM 400’s, 1971 Husquvarna 400, 1983 Honda V65 Magna, 1987 Suzuki 230 Quad, 1987 TW200, 1990 TW200, 1996 Honda XR 650, 1998 Yamaha 300 King Quad, 2000 Harley Davidson Heritage, 2006 Kawasaki KLX 250s, 2007 Arctic Cat 650 Quad, 2010 Polaris Sportsman 850 Quad, 2006 Yamaha Grizzly 660 Quad, 2002 TW200, 1995 TW200, 2008 TW200, 2016 TW200.
    Oct 2018
    630
    Trimmed and zip tied. Then they fit perfectly
    Triumphs
    ATVs
    Jan 2018
    Vancouver Island
    18
    This comes up when I search for Tw200 extended range tank, any thought if this would easily fit?
    Pleasanton, CA
    5,632
    Quote Originally Posted by BikeNbowHNTR View Post
    I doubt it, but who knows?
    Go ahead and order one and see if it will work (but make sure that you can return it if it doesn't work).
    Mar 2017
    Yuba City, CA
    376
    I have a tank (2.7 gal), seat, and plastics off a TTR225 I'll give you, if you want to try to use them.
    I also cut off the section of frame where the tank mounts, so you can copy it on to your TW frame.
    I was going to try this myself... but I've just got too much going on.
    I'll cover shipping to Seattle, if you have a place I can send them for you to pick up.
