LED turn signals on the cheap - Page 3
Results 21 to 30 of 33
Like Tree40Likes
Thread: LED turn signals on the cheap
  1. #21
    Jun 2016
    New Rochelle, New York
    1,709
    What did you do to make it (the one you have hooked-up) work correctly? Capacitor/resister?
    1995 BMW K75 (Elec Start)
  2. #22
    Oct 2018
    Rural, South Carolina
    630
    Quote Originally Posted by FIRE UP View Post
    Well Sir,
    You either got lucky or, you just plain bought a better set than I just did. Before I saw your write up here and video, I'd already done a bit of research and found what appears to be, an almost exact same set only, I paid $15.99 on Amazon for mine. They are supposed to be, just like yours, in the fact that they are "sequential" (kind-a like the old Cougar cars and newer model Mustangs). But, when I hooked only one up, the right rear one, it just flashes a little on the left side but, does not "sequence" like yours. Hmmmm, not sure here. I might have to add some form of a resistor to the positive line, near the signal. I got some hanging around so, I might give them a try. I'm still kinda new here so, I don't know if I'm aloud to post a short, 5 second video of mine in action. You'd get a better idea of how it's operating instead of me telling you. I sure like yours and, the ad for mine was stipulating that mine are to act the same as yours but, ain't happening.
    Scott
    P.S. Well, I still don't know how to upload a video. Tried it several times on various forums and it never works. Oh well. Suffice to say, my LED turn signal does now work like yours. I don't know if it makes a difference if only ONE is hooked up or not.
    I did not add nor modify anything this includes resistors, capacitors, diodes, transistors, ICs, etc. I just hooked them up and they work. Keep in mind these are only two wire signals. You have three wires on front for "running" light purposes. Make sure you are using the correct two wires. I did not use the blue. Not sure if that would result in what you are seeing however. The only other thing that is different on my bike (electrically that is) is I have a Lithium battery. Again highly doubtful that makes a difference.
    2010 TW200 - The Goat
    Triumphs
    ATVs
  3. #23
    Member FIRE UP's Avatar
    Jun 2019
    Lake Havasu City AZ
    61
    Shtrnromr,
    I surely thank you for answering me here. I didn't mess with the front, only the right rear. So yes, there's only two wires to goof around with. I highly doubt also that your type of battery has anything to do with the operation of a turn signal, be it sequential or not. I'm not sure it's worth messing with at this point, as in return what I presently have and order up the exact ones you got or, simply hunt for some other models that are not sequential. Even though mine were ony $15.99, if I mess with one by adding a resistor to it, THEY'RE MINE, and I can't return them. Losing $16 ain't gonna put us in the poor house. But, I sure like the sequential. We'll see what transpires today. Thanks again for your answer. Very much appreciated.
    Scott
    P.S. On edit: Also Sir,
    From your video, it appears the one shown is on the left front, correct? May I ask, did you install any others prior to the video or, are all four installed? Did you test the sequential operation of just one installed while its mate, front or rear, was still the incandescent bulb? What I'm trying to analyze here is, if the one I see in your video is just the left front, and the rear is still your original ( I may have things wrong here, normal for me) maybe that has an affect on how things work. Just guessing here.
    Scott
    Sthrnromr likes this.
    Retired SDFD, 30 years,
    2004 Itasca Horizon 36GD CAT C-7 330HP
    2008 Honda GL1800 Goldwing Caliente red
    2007 TW 200 "Blue Noid"
    2115 Jeep JKUR Rubicon
    2011 GMC Sierra 1500 Extended Cab 4x4
    HAM, KI6OND
    Me, the wife and our killer Mini Schnauzer, "Sophie"
  5. #24
    Oct 2018
    630
    @TW-Brian
    Brian, you purchased the same signals I have. Can you verify or deny they work as mine do in video posted above without the need for any resistors, etc.?
    Triumphs
    ATVs
  6. #25
    Jun 2019
    Lake Havasu City AZ
    61
    Quote Originally Posted by Sthrnromr View Post
    @TW-Brian
    The answer to this question would be a tremendous help in my decision making for returning the ones I purchased and, purchasing the same ones you and Brian did.
    Scott
    HAM, KI6OND
  7. #26
    Pleasanton, CA
    5,634
    @TW-Brian
    Scott
    I will try and see if I can these turn signals mounted up in the next week or so and then report back on how they work for me.
    Brian
    littletommy and Sthrnromr like this.
  8. #27
    Oct 2018
    630
    Brian
    Thanks Brian. I just tested with bike off and bike running and timed all four. They work flawlessly in both scenarios. I am thinking the internals and/or draw are a bit different in the ones we bought off of eBay compared to the ones purchased off of Amazon by Scott (FIRE UP). Your test would confirm that. I have no other explanation. Mine are working perfectly front and rear and exactly as shown in the vid I posted....
    littletommy likes this.
    Triumphs
    ATVs
  9. #28
    Jun 2019
    Lake Havasu City AZ
    61
    Brian & Frank,
    I surely do thank you for trying to help me here. No need to rush Brian. At present, I've decided to keep it all stock right now. I found an exact replacement right rear turn signal for $21 to replace my broken one. And, knowing my luck, yours will work as good as Franks do but, If I bought them and installed them, they'd act funny. There's a real good chance I'll be doing the change-over to LED turn signals in the not too distant future 'cause, I like the brightness of them compared to incandescent bulbs. I really like those ones you're gonna install and Frank already did. Those are most likely, what I'll be going to. I haven't even had a chance to not only ride this new-to-us Blue Noid but, I haven't even started it since we bought it a week ago. Rust in the tank, missing lots of stuff, carb gummed up and a whole lot more. So, tomorrow, may be the first time I get it running when my new fuel petcock comes in. Heck, even my spark plug boot, the bakelite one, is busted up from whatever kind of fall the previous owner did. So, I got more stuff coming. Thanks again but, please do report back with your results of the install, definitely curious.
    Scott
    HAM, KI6OND
  10. #29
    Junior Member jstuewe's Avatar
    Jun 2018
    Round Rock, TX 78681
    8
    I put these on right at a year ago and have a few thoughts.
    - I got the $15 ones on Amazon. https://www.amazon.com/gp/product/B07CSS4LLL
    - They're super flexible and would be very hard to damage
    - The wiring connectors are plug and play. No tools or wiring necessary!!
    - They blinked super fast and didn't work right until I replaced the blinker module with a $10 solid state version from Amazon. It's also plug and play with the OEM part so it's much easier than messing with resistors.
    "2-Pin Electronic LED Flasher Relay FIX Motorcycle Turn Signal Bulbs Hyper Flash" from https://www.amazon.com/gp/product/B073J82PNF
    - 2 rides after I put them on they were both loose. Tightening them up just pushed the rubber off the threads so I put a nut on both sides so I could tighten them against each other and haven't had any more problems.
    - My riding buddy says they aren't very visible during the day. I try and stay off asphalt so I'm not worried about it. :-)
    - Last week one of them lost about half the LEDs after right at a year after I put them on. I had only installed two so I had a spare.
    Hope my insights help.... Ride on!!
  11. #30
    Member Willys714's Avatar
    Feb 2012
    68
    2 rides after I put them on they were both loose. Tightening them up just pushed the rubber off the threads so I put a nut on both sides so I could tighten them against each other”
    I bought a bunch of these off DX ($2ea. In qty.) and had the same problem with the rubber coming off the stud, so I used the jam nut solution too. I also safety wired the rubber onto the stud. Very poor design but a cheap and easy fix.
    They are actually crash worthy now and I am constantly testing them
    UncleRandy likes this.
