kangaroo's little blue burro Pepe - Page 5
Page 5 of 7 FirstFirst ... 34567 LastLast
Results 41 to 50 of 63
Like Tree57Likes
Thread: kangaroo's little blue burro Pepe
  1. #41
    Member kangaroo's Avatar
    Jun 2019
    SF Bay Area, Cali
    52
    Fork brace
    There's a slight wander I noticed when riding. It became more noticeable without the front fender and that sheet metal brace. Decided to help the front axle from doing all the work. Bolt pattern turned out to be 175mm x 59mm. M6 tapped into brace. Will see how it makes the front end feel.
    coldbay and Darth like this.
    2006 Tw200
  2. #42
    Senior Member Errtu's Avatar
    Jul 2017
    Buena Vista, CO
    139
    Since you can bend that fender brace by hand, I don't think it adds any stability.
    2001 Yamaha TW200
    2015 Nissan Xterra PRO-4X
  3. #43
    Jun 2019
    SF Bay Area, Cali
    52
    Maybe something else is going on. I'd like to see if the bracing makes the forks "work" better. God knows they need all the help they can get. I'm also experiencing a pull to the left. I've played with the rear wheel alignment and it has not helped.
    2006 Tw200
  5. #44
    Jun 2019
    SF Bay Area, Cali
    52
    Taillight/fender mod mounted. Kinda/sorta works. Better than before.
    2006 Tw200
  6. #45
    Jun 2019
    SF Bay Area, Cali
    52
    All wired up. Not bad for a late night $20 eBay buy.
    2006 Tw200
  7. #46
    Jun 2019
    SF Bay Area, Cali
    52
    Left rearset
    Fixed the right rearset and now the left rearset started getting my OCD going. So spent some time measuring and fixed the footpeg "stagger" by moving up the footpeg about "1/2 to 5/8".
    2006 Tw200
  8. #47
    Jun 2019
    SF Bay Area, Cali
    52
    Mounted. Had to remove material from the engine case to clear. Also filed down the rearset to clear frame welds. Pegs are more symmetrical now.
    2006 Tw200
  9. #48
    Jun 2019
    SF Bay Area, Cali
    52
    Hmmnnn maybe not. Lol about 1/2” higher and 1/4” further forward at the peg pivot in relation to the swingarm. Think I need to rotate the 2nd mounting points about 20 degrees along the axis of the big bolt.
    2006 Tw200
  10. #49
    Poway CA.
    2,102
    When can I drop my bike off at your place Roo!
    Nice looking mill work.
    ronnydog
  11. #50
    Jun 2019
    SF Bay Area, Cali
    52
    Thanks! I'd have left the bike alone if I didn't crash! Well that's not really true either. lol
    I'm thankful for you forum veterans on getting my bike back up running faster. Y'all did the heavy lifting. Most of the upgrades were inspired to "fix" shortcomings.
    2006 Tw200
