Fatcat bars plus risers
Results 1 to 3 of 3
    Senior Member Tiny-Wheel-200's Avatar
    May 2013
    Wasilla, Alaska
    725
    Added risers to my existing fatcat bars for a total of about 6 inches of rise to tge grips. It really feels amazing on trails and when youre standing up. Really makes the bike come alive.
    May 2013
    Wasilla, Alaska
    725
    Forgot to add. At that 6 inch rise point you are approaching the point where you could be constrained in raising it much further by the clutch cable and if you have a drum front perhaps by the brake cable. The throttle cable could go a bit higher but you may need to rotate it a bit to do that. I should add that all of my cables were rerouted to put an atv tire on the front also.
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,782
    What? No Ape Hangers?
