Extended Air/Fuel Screw For TW200
Results 1 to 10 of 10
Like Tree6Likes
  • 2 Post By jeepster09
  • 4 Post By nobade
Thread: Extended Air/Fuel Screw For TW200
    Senior Member TeeDoubleUTwoHundred's Avatar
    May 2019
    Ontario, Canada
    192
    Good Afternoon,
    I was just curious if anyone has tried one of these;
    https://www.amazon.com/Accessories-M...gateway&sr=8-1
    The price is pretty decent, but shouldn't these be made from brass, rather than aluminum? Also, to install this new screw, do you just back the old one out and put the new one in, or is there more involved? I'm willing to give it try, if no one with carb experience sees a problem with it.
    Anyways, thanks for reading.
    2017 TW200 -> Hand Guards-Chain-Foot Pegs-Skid Plate-Shifter-Grips-Mirrors-Fuel Filter-Fender-Levers
    Senior Member Errtu's Avatar
    Jul 2017
    Buena Vista, CO
    135
    Interested to find out how well it works. That price is ridiculous though.
    2001 Yamaha TW200
    2015 Nissan Xterra PRO-4X
    18,729
    Comparably priced compared to the custom order silver soldered ones that used to be made by a member here for us.
    If it makes you feel like you are getting better value then go ahead and order the Amazon one in Titanium.screw.jpg
    Unfortunately they don't have Betty Boop's exact shade of orange....girls like to be color coordinated, right?screw2.jpg
    Jul 2017
    Buena Vista, CO
    135
    I would much rather support a member that is hand making them.
    Think of the weight savings you will get with the titanium one!
    2001 Yamaha TW200
    Senior Member jeepster09's Avatar
    Nov 2010
    Twin Cities Minnesota
    242
    I would pass considering it is made of aluminum. With a little corrosion or mud, I would think it would be pretty easy to strip threads.
    "Life Member NRA"
    Member MtnMan75's Avatar
    Jul 2019
    MD, USA
    86
    It is aluminum, but 6061-T6 is quite comparable to brass in strengths and in some categories is better. I don't think it should hurt anything. Personally... if it's going to be sticking out that far I would want something that conducts heat a bit less like the 6061 vs. brass. Only one way to find out, and that makes you the distinguished guinea pig of the day!
    Word of advice. From the threads up - take note of any (and I mean the ever so slightest) differences in size and tapers between the stock and this one. A minuscule difference will translate to a lot more or a lot less flow through the pilot circuit and you may either need to have it turned almost all the way in, or it's so far out that continuing to turn it makes no difference. It's quite amazing how such a slight change in the taper on the mixture screws can prove a drastic change in the number of turns it takes or if it is even usable.
    Just one more note: I don't know your setup, but just making sure you realize this is for an FCR carb, and not a CV?
    Hailey, ID
    3,346
    Why bother? Once you have found the right number of turns out you will probably never change it for the life of the bike, unless you go through major altitude changes, like 10,000 feet.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member TWBigBlake's Avatar
    Apr 2019
    Tacoma, WA
    200
    I picked up one of these from a guy in Cali, got the info from one of the forum members here. I think it was like $50
    Jul 2017
    Buena Vista, CO
    135
    Does it work on our carb? I seen these for sale on ebay but not sure if it fits.
    2001 Yamaha TW200
    Member nobade's Avatar
    Aug 2011
    Albuquerque
    32
    I recently decided to cheat, and drilled a hole in the end of my mixture screw and soldered in a 1/16" Allen wrench, cut off to stick out just enough. It works great and didn't cost anything. As a bonus it's really easy to tell how far I've turned it by where it's pointing.
    Sent from my SM-J737V using Tapatalk
    CJ7Pilot, MtnMan75, Fred and 1 others like this.
