6 plate clutch options
Results 1 to 7 of 7
    Member 300stw's Avatar
    Oct 2015
    64
    was there a writeup about installing a 6 plate clutch setup in the tock tw,
    i purchased a complete 6 plate clutch and basket from an 1987 tt225 and wondering if i can use it,,,,
    18,711
    Unless you also get the TTR225 right ride cover the assembly will be a little too wide for the stock TW right side cover unless you shave cover and trim bolt on clutch assembly as TW-Brian pointed out in the thread about using PlacerLode's output shaft extension for mating a XT or TTR engine in a TW frame. It should be possible, just not a simple plug-n-play...do yourself a favor and get the TTR right side cover.
    #242 Right Engine Clutch Cover Case Yamaha Serow XT 225 XT225 1992-2000
    Pleasanton, CA
    5,720
    I am not familiar with the TT225 engine, but it appears to be a different animal than the TW200/TTR225/XT225 engines.
    I do not think that the 6-plate clutch baskets from the TTR225/XT225 engines will be a direct bolt up onto a TW200 engine as I believe that the splines on the shaft that the clutch baskets mate to are different.
    That's all I got.
    Oct 2015
    64
    i remember someone posting about the tt225 hub having the same splines, ect thats why i bought it, but me and the search function are not finding it,
    since i have it i was gonna install it till i get a shaft extension and install a xt225 engine, probably dont need it right now, but the big atv tire and the areas i elk hunt with 13-65 gears is hell on the clutch
    Oct 2015
    64
    i looked at that cover, is the kickstart hole the right diameter, i see it has a plug in it
    6,975
    Quote Originally Posted by 300stw View Post
    .......... with 13-65 gears is hell on the clutch
    13/65 should be easy on the clutch.
    Get a Barnett Kevlar clutch.
    18,711
    Sorry, thought it was a TTR, not TT clutch pack under consideration. My mistake, know naught of TT engines.
    However am surprised to hear of the overworked clutch. While I'm not dragging elk carcasses my 13 x 55 gearing seems to haul my carcass without complaint up many a sustained ascent. Maybe 300stw's steep trails are steeper than my idea of "steep".
    Kickstater hole's knock-out receives an oil seal prior to kick starter installation. Presumes case has corresponding machining for other end of kicker shaft.
