Raising the handle bars
Results 1 to 8 of 8
    Junior Member orrsmills's Avatar
    May 2019
    New Windsor NY
    22
    I would like to raise my handle bars. I do not want to replace the existing bar, just raise them. Can this be done, do they sell a product to raise the bars? If so, are the cables long enough to accommodate this type of modification?
    Any info would be appreciated.
    Thx.
    Pleasanton, CA
    5,717
    Yes, the TW handle bars can usually be raised about 2" by just cutting zipties and re-routing the cables a bit. Here is one example of a set of bar risers that not only raise the bars, but also allow you to rotate them a little either fore or aft. These can be found on eBay or Amazon
    May 2019
    New Windsor NY
    22
    Anyone try the Ape Racing riser's from Amazon?
    Senior Member jeepster09's Avatar
    Nov 2010
    Twin Cities Minnesota
    232
    Go to Procycles web site you will find everything you need and even stuff you don't need but MUST HAVE
    https://procycle.us/bikepages/tw200.html
    "Life Member NRA"
    Senior Member Michael Bryce Winnick's Avatar
    Oct 2015
    836
    Rox risers are the best risers in the world. Nobody should get any other risers than Rox risers, Everyone with a TW should get Rox risers.
    https://roxspeedfx.com/products/2-pi...-7-8-handlebar
    Designed, Manufactured, and Assembled in the USA.
    The cables may need a little rerouting, but no need for replacement. Get the silver finish. They look better and help more with wheelies.
    May 2019
    New Windsor NY
    22
    Quote Originally Posted by Michael Bryce Winnick View Post
    yeah i was leaning towards them. The ones in your link are sold out.
    Senior Member Tiny-Wheel-200's Avatar
    May 2013
    Wasilla, Alaska
    722
    The clutch and throttle limit out at 4 inch of rise rerouting the cables. I have a different brake so I'm not sure about that cable. Raising the bars is one of the best mods you'll ever do
    Senior Member GCRAD1's Avatar
    Jul 2017
    SoCal
    183
    If you are running the stock size handlebars, this is how I did it:
    I've chosen the ZETA 22.2mm bar risers as the 22.2mm ProTaper CR Hi SE (7/8 aka: Seven Eighths)
    Bars came on the bike from the previous owner. It is the cheapest way for
    me to get the bar height I want for now, as I am not sure what bars/bend
    I want to go with. For now, this is how I will roll. (back then)...
    See my whole post within my thread:
    https://www.tw200forum.com/forum/tra...tml#post706401
    Quote Originally Posted by orrsmills View Post
    Thx.
