Plastic gas tank street legal ?
Results 1 to 10 of 14
    Member Cagiva's Avatar
    Oct 2012
    Wilmington , DE
    32
    I just got a Clark 2.7 gal. gas tank and have not put it on yet. I have read a lot of the post and they are very informative. I also did not like my logo so opted to get a plastic tank (black) and I found white vinyl tuning fork logo stickers I think will look cool on it. My question , are the plastic
    tanks street legal and will they pass inspection. On the bottom of the tank it says " for off road use
    only " Is the Clark Co. just covering its butt or is there a reason the plastic tank is not as safe on the road as a metal tank ?
    May 2012
    Tucson, AZ
    976
    Quote Originally Posted by Cagiva View Post
    You have to check your state and local laws, there should be links to the actual statutes on your state's DMV or DOT website.
    I know that in NC (where I used to live) there is an explicit requirement that street legal motorcycles have a metal gas tank.
    In AZ where I live now, there is no such requirement. It's just different everywhere, so you really have to check for yourself.
    2012 KLR650
    - Sold
    2013 Tiger Explorer XC
    2014 CB500X - RRP L3
    May 2012
    Tucson, AZ
    976
    I was curious, so I checked out the Delaware Vehicle Inspection Manual. It's a .pdf
    I don't see anything in there about metal or plastic gas tanks. Not to mention, your DOT website is a bear!
    PLEASE NOTE: I am not a lawyer! Seriously, I have no idea what I'm talking about, but this is what I dug up because I'm bored.
    MOTORCYCLE INSPECTIONS
    PROCEDURE:
    All motorcycles presented for any DMV inspection must be ridden under their own power into the lane and cannot be inspected while on a trailer or truck.
    1. Fenders – must have front and rear. REJECT IF: One or more fenders are missing.
    2. Headlamp – shall have at least one or not more than two; height not more than 54” nor lower than 24”. Must have high and low beams. Must show a white light (fed. reg.)
    REJECT IF: Any headlamps inoperative or no high or low beam.
    3. Tail lamp – shall emit red light plainly visible from 500 feet. At least one not more than 72” high nor less than 20”.
    REJECT IF: Light not installed; shows white light, inoperative or light is weak.
    4. Stop lamp – at least one; visible from 100 feet in normal sunlight. Must be activated by application of front brakes and rear brakes on vehicles manufactured after January 1, 1969. Must have 8 square inches of lighted lens.
    REJECT IF: Lamp does work by both brake controls, the lens is broken, or the lighted area is too small.
    5. Tag lamp – so placed to illuminate tag with a white light and render it clearly legible from a distance of 50 feet to the rear.
    REJECT IF: Lamp not operating or installed.
    6. Reflectors – up to 1976 model year shall have at least one on the rear at a height of no more than 60” or less than 20”. 1977 and newer models require five reflectors. The reflectors must have 4 square inches of reflective area.
    REJECT IF: Reflectors not installed or too small.
    7. Turn signals – required on all motorcycles manufactured since 1974. Minimum 3-1/2 square inches of luminous lens.
    REJECT IF: Turn signals are inoperative, weak, or do not flash. If size is less than 3-1/2 square inches of luminous lens on 1974 or newer models. Rear must be a minimum of 9 inches of separation from center of lense and 16 inches on the front.
    Revised 9/12
    - 70 -
    This circle = 3-1/2 square inches
    This rectangle = 3-1/2 square inches
    8. Horn – must be audible for 200 feet under normal conditions. Sirens, whistles, and bicycle horns are prohibited. Horn button must be on the handlebars close to handgrip.
    REJECT IF: Horn weak or inoperative, wrong type of horn or horn button in wrong place.
    9. Mirror – at least one so placed to readily ascertain the presence of vehicles approaching from behind or following.
    REJECT IF: Mirror not installed or placed in an unusable position.
    10. Muffler – must be installed. Perform Test DMV2001-01 on all motorcycles. REJECT IF: Muffler is loud, not baffled, leaks or does not conform to DMV Standard
    2001-01.
    VEHICLE
    NOISE STANDARDS
    TYPE/AGE
    ENGINE RPM (approx.)
    2500/3000
    Above idle
    2500/3000*
    2500/3000*
    2500/3000
    MAX. NOISE (dBA)
    95 – 96.5**
    95 – 96.5**
    98 – 99.5**
    100 – 101.5**
    95 – 96.5**
    Cars, LT Trucks 8,500 pounds or less
    Cars, LT Trucks All diesel
    Motorcycles
    1976 or Newer
    Motorcycles 1975 or Older
    All
    8,501 pounds or more
    Engine RPM Range for Noise Test
    2000 - 2500
    2225 - 2725
    2450 - 2950
    2675 - 3175
    2900 - 3400
    3125 - 3625
    3350 - 3850
    3575 - 4075
    3800 - 4300
    4025 - 4525
    Tachometer Red Line
    5000
    5500
    6000
    6500
    7000
    7500
    8000
    8500
    9000
    9500
    Tachometer Red Line
    10000 4250 - 4750
    10500 4475 - 4975
    11000 4700 - 5200
    11500 4925 - 5425
    12000 5150 - 5650
    12500 5375 - 5875
    13000 5600 - 6100
    13500
    14000
    14500
    15000
    5825 - 6325
    6050 - 6550
    6275 - 6775
    6500 - 7000
    Note: Sound testing is under a moratorium, until further notice, test will be performed if a police check is required.
    11. Tires – must have a minimum of 2/32” of tread being uniform not cupped. REJECT IF: Tires have less than 2/32” cupped.
    12. Footrest or pegs – all motorcycles shall be equipped with footrests. REJECT IF: One or more missing or broken.
    13. Chain – must be kept tight; adjusted according to manufacturer’s specifications. REJECT IF: More than 3⁄4-inch play.
    Revised 9/12
    - 71 -
    14. Brakes – all brakes shall be maintained in good working order and shall be adequate to control the movement of and to stop and hold the motorcycle.
    REJECT IF: Front and rear brakes not working—both required on motorcycles manufactured after January 1, 1969.
    15. Speedometer – must be equipped with a speedometer in good working order. REJECT IF: Not installed or not working.
    16. Display of number plates – the license plate assigned to the motorcycle shall at all times be securely fastened to the rear of the vehicle at a height not less 12” from the ground and maintained in a condition to be clearly legible. The plate must be mounted horizontally. The plate can be to the left or right of the rear fender but must mount between the rear fender and the rear axle.
    REJECT IF: Plate not securely fastened or obscured so that letters, numbers, or “Delaware” cannot be identified. If registration sticker covers any number or letter or if the plate is covered with plastic or tint material. If the plate is mounted vertically. If the plate is further forward than the rear axle.
    17. Chain guard/drive pulley cover – required if originally equipped 1969 or newer. REJECT IF: If chain guard/drive pulley cover is missing, broken or cracked. Note: Some
    motorcycles are factory equipped with a chain guard that does not cover the rear half of the chain—these vehicles will not be rejected.
    18. Helmet – required for every person operating or riding on a motorcycle. REJECT IF: Helmet is not in the possession of the operator.
    2012 KLR650
    - Sold
    Senior Member FortPayne's Avatar
    Nov 2011
    Alabama
    326
    Wow that was detailed.
    Quick answer is no its not technically street legal (supposedly because of the expensive testing required) and yes to cover their butts.
    No cop is going to look under the tank and you should be just fine. If an inspection is required and it worries you, throw the old tank back on long enough for the inspection.
    Tenaciously Deviant Unwittingly Brilliant
    Oct 2012
    Wilmington , DE
    32
    Quote Originally Posted by DonBenito View Post
    PROCEDURE:
    Revised 9/12
    - 70 -
    2001-01.
    VEHICLE
    NOISE STANDARDS
    TYPE/AGE
    2500/3000
    Above idle
    2500/3000*
    2500/3000*
    2500/3000
    MAX. NOISE (dBA)
    95 – 96.5**
    95 – 96.5**
    98 – 99.5**
    100 – 101.5**
    95 – 96.5**
    Motorcycles
    1976 or Newer
    All
    2000 - 2500
    2225 - 2725
    2450 - 2950
    2675 - 3175
    2900 - 3400
    3125 - 3625
    3350 - 3850
    3575 - 4075
    3800 - 4300
    4025 - 4525
    Tachometer Red Line
    5000
    5500
    6000
    6500
    7000
    7500
    8000
    8500
    9000
    9500
    Tachometer Red Line
    10000 4250 - 4750
    10500 4475 - 4975
    11000 4700 - 5200
    11500 4925 - 5425
    12000 5150 - 5650
    12500 5375 - 5875
    13000 5600 - 6100
    13500
    14000
    14500
    15000
    5825 - 6325
    6050 - 6550
    6275 - 6775
    6500 - 7000
    Revised 9/12
    - 71 -
    Oct 2012
    Wilmington , DE
    32
    Thanks Don Benito .
    The site sure is a bear ! Thanks for taking the time.
    Oct 2012
    Wilmington , DE
    32
    Quote Originally Posted by Fort Payne View Post
    Oct 2012
    Wilmington , DE
    32
    Thanks, great answer !
    Senior Member Dubster's Avatar
    Nova Scotia Canada
    583
    I am not sure if my Clarke tank is legal here or not.Mine is the clear one and I had it on all last summer with no problems and passed by plenty of cops.I will find out for sure when I get the bike inspected and if it doesn't pass I will install the stock tank long enough to get a sticker.
    Speaking of stickers unfortunately vinyl stickers will not stay on the plastic tank long before they begin to bubble. DAMHIK
    09 DL650 V-Strom "Function over Form at a Superior Price"
    09 DR650 "Hooliganizer"
    03 TW200 "No Road---No Problem"
    81 Z50 "Just Because"
    98 Honda Valkyrie "Fast as [email protected]&K"
    02 Tw200 " Camouflaged Redneck Edition" Sold to Son-in-Law
    73CT Trail90 "The most fun you can have under 100cc's" Sold. Had an offer I couldn't refuse.
    Sep 2011
    Southcoast MAsshole
    2,661
    Here in MA i had an inspection station tell me that a plastic tank was illegal but they were wrong...everything is pretty strict here but if you go to a chopper bike shop to get inspected they don't seem to care much...
    (14) Fuel System. Check fuel system and controls and reject motorcycle if:
    (a) There is fuel leakage at any point in the system.
    ( Any part of fuel hoses are not securely fastened or fuel tank is not securely mounted.
    (c) Fuel tank cap is missing or can not be properly secured.
    (d) Throttle does not return to idle position when activating force is removed, if so equipped.
    (e) Fuel hoses are chafed, cracked, split or swollen or are not a fuel resistant type.
    (f) Fuel hoses are routed in proximity to or in contact with high temperature engine parts
    pg 30...
    http://www.massrmv.com/rmv/inspect/540cmr400.pdf
  1. Biggest Street legal tire?
    By Homeskool in forum Performance and Customization
    Last Post: 06-06-2013, 09:54 PM
  2. Side by Side Street legal in Tennessee?
    By Xracer in forum Off-Topic
    Last Post: 01-05-2012, 06:53 PM
  3. 1999 Gas tank and plastic for sale
    By Boarder255 in forum TW200 Classifieds
    Last Post: 12-23-2011, 11:39 PM
  4. Street legal bike, Forest Service roads, unlicensed rider?
    By MrDNA in forum General Discussion
    Last Post: 04-25-2011, 09:59 PM
  5. Street legal?
    By rp3 in forum General Discussion
    Last Post: 03-25-2011, 11:47 AM
are clarke gas tanks street legal
are plastic clark tanks street legal
are plastic gas tanks street legal
are plastic motorcycle tanks legal
gas tank tw200
is a plastic tank road legal
is a tank street legal
metal gas tank for motorcycle street legal
motorcycle plastic gas tank legal
plastic gas tank not street legal
plastic tank legal on road motorcycle
tw200 gas tank
