Marvin Shaw Shocks...
Results 1 to 10 of 16
Like Tree24Likes
Thread: Marvin Shaw Shocks...
    Senior Member TWBigBlake's Avatar
    Apr 2019
    Tacoma, WA
    232
    Ok... long story (not so) short, a series of unfortunate events with the banshee shock and just getting plain old tired of swapping in and out, testing, trying to get nitro filled... I abandoned ship to pursue an endeavor for a quality designed part, which inadvertently led to a great experience.
    Consulting my friend on shock options... I have to share this text message:
    The cool part is after working with MSS with measurements and weight, they managed to handle biz with one of their front shocks since I was working off of the banshee dimensions, resulting in a much lower ($260) price point. Total was a little more because I had the shock body and spring powder coated.
    Second cool part, as Fred mentioned to me in a post and became a legitimate problem was the extra travel of the banshee shock... there is approx 1.5 inches extra movement the swing arm gets, that lets the tire scrub the bottom of the seat pan when you hit big bumps...
    MSS took care of that by hydro-locking the last 1.5 inches of travel to prevent that.
    Going to install in the morning, will report back after test ride over varying terrain.
    Senior Member reddave's Avatar
    May 2018
    South Park, CO
    324
    Nice! Chances are you'll be getting Marvin some more business after posting this up!
    1987 Yamaha TW200
    Junior Member Skinny06's Avatar
    Jul 2019
    PNW/Seattle
    25
    Yeah, wow. That is awesome service, and a damn good price for a unit.
    Crap. Now I don't know what I need next for the Tdub. . .
    2016 TW Unmolested as of yet.
    18,833
    That is a surprisingly reasonable price since previous custom shock work by others has been quoted at twice the cost.
    littletommy likes this.
    Apr 2019
    Tacoma, WA
    232
    Installed and tested this morning, on big bumps still hits the seat pan. Compression feels just a little soft, rebound was perfect, just a little too much travel. Working with Tim at MSS to get the hydro lock distance dialed in, going to mark the shock and send it back for adjustments and to get a little more pressure added.
    I'd hold off on ordering till we get the measurements dialed in. This is the first one he's built for the TW.
    On a side note, aside from needing washers/spacers the fit on the bike is beautiful... the pressure valve clears the shock top plate and doesn't get in the way of the seat or wiring, and has no interference at the bottom. If you have a pressure regulator that can go high enough, you can just pop the seat and adjust the shock pressure for a stiffer/softer compression.
    Darth, Trail Woman and tylermoney like this.
    Jun 2015
    Nova Scotia
    1,406
    Sounds good. Is he rebuildiing/customizing the banshee or basing a new custom build off of the banshee design specs?
    Apr 2019
    Tacoma, WA
    232
    Quote Originally Posted by Trail Woman View Post
    Absolutely, it's a custom build based off of the banshee dimensions. So, for me, I like the bike to initially sit that .5" higher, for those that don't, or have shorter legs, I'm sure you can just have the shock shortened.
    Trail Woman likes this.
    Jun 2015
    Nova Scotia
    1,406
    Even better...I'm looking to go 1" longer shock for 2-3" taller seat height myself. Turns out my r6 shock needle bearing is not fixable so this sounds like a good route to go.
    Apr 2019
    Tacoma, WA
    232
    If I ship the shock Monday, I might have it back by the weekend or following week. I'll let everyone know how the next test goes.
    Trail Woman, joeband and admiral like this.
    Apr 2019
    Tacoma, WA
    232
    Shock is off, mailing it out tomorrow. Hopefully I'll have it back next week.
    Pilot Jet 34 and Sthrnromr like this.
