FMF pipe doesn’t fit
Results 1 to 10 of 12
Like Tree15Likes
Thread: FMF pipe doesn’t fit
    Junior Member Dirtjet's Avatar
    Feb 2017
    Carefree, Pine AZ
    20
    I bought a new FMF pipe from OEM cycles (part number 044312). When the header is all the way in and the aft mount is lined up, the forward mount is 7/8 inch too far aft. I called OEM and FMF and they both say it should fit. I’ve seen some feedback that states the same problem that I’m having. Anyone have the same problem?
    I could probably fabricate a bracket but it’s BS that I should have to do this.
    $18 out of pocket to ship back. I may just ship back and stick with the stock exhaust.
    Biking through Africa with Cornelis
    17,593
    Make a little bracket. It's Yamaha's fault, somewhere along the line they changed the mounting point. Why? Heck if I know...
    Purple, 762x54 and CJ7Pilot like this.
    1st John 1:9
    John 3:16
    John 3:17
    Junior Member 762x54's Avatar
    Sep 2019
    8
    It's that way sometime. I rode Harleys in the 70's & 80's, every replacement part came in a box with a rat-tail file for adjustments.
    Oct 2018
    Rural, South Carolina
    689
    I'll make you a bracket for $18 ;p
    In all seriousness though, I know it's frustrating and you're right it should fit. But alas, tis the world of modifications sometimes. If you were local, we could fab in my barn in prob ~10 mins.
    Offroad:
    TW200 - The Goat
    KTM 300 - Orange Dragon
    ATVs
    Onroad:
    Triumphs (mainly)
    Senior Member jeepster09's Avatar
    Nov 2010
    Twin Cities Minnesota
    291
    Aftermarket=You gotta modify it to fit.
    grewen likes this.
    "Life Member NRA"
    17,593
    A little piece of flat strap iron with two drilled holes should do the trick.
    jeepster09 and grewen like this.
    1st John 1:9
    John 3:16
    John 3:17
    Senior Member Michael Bryce Winnick's Avatar
    Oct 2015
    855
    When you are done, order in a Clarke Racing tank. You can fab your right plastic on to match the FMF pipe bracket. Your bike gets that much better each time you do something like this. You may get a deduct at Pebble Beach, but you will enjoy the hell out of the job and the better pipe and better tank. FMF did not do you wrong. Yamaha has a sense of humor. Don't put your factory exhaust back on. Why would you hum along with Barry Manilow when you can be on your TW rocking to Steppenwolf.
    littletommy likes this.
    Feb 2017
    Waretown NJ
    556
    300 dollars for an exhaust you should not need to take a rat tail to it or be fabbing brackets
    87 TW
    Nov 2010
    291
    By your picture, simple fix, do what Tommy suggests with little strap of band iron and drill 2 holes. That would be easier than sending back.
    My experience with aftermarket is nothing ever fits as it should. Just do the simple mod and move on.
    "Life Member NRA"
    Nov 2010
    291
    Quote Originally Posted by Maxpower View Post
    Yaaa you shouldn't have to, but more often than not you do have to. Otherwise plan on never doing any upgrades. Sadly it is the norm and not the exception.
    "Life Member NRA"
