yz80 forks... again
Results 1 to 7 of 7
    Junior Member wrstlr119's Avatar
    SW Ohio
    19
    To introduce myself I bought a 91 tw as a cheap first bike to ride with my dad on his new crf250l (way too tall for me at 5'4, 140). After riding it a couple of times, I noticed some problems with the bike which has led to almost a complete rebuild. The forks were bent (one was bent badly and had a crease) so I decided on the yz80 forks as a cheaper replacement which leads me to my question.
    What internals would you guys recommend for a lighter rider who plans on doing casual backroad/trail riding? Should I leave it stock (with longer spacers) and experiment with oil level/viscosity? Yz springs + air? Stock with the YZ bottoming springs as spacers? Or am I over thinking all this?
    PS: I plan on lowering the forks in the triples to stock ride height if that wasn't apparent.
    Desert, SoCal
    7,369
    I recomend that you not fix it unless it's broke, particularly if you're a light weight rider.
    Put it together using stock parts, 10wt. at stock oil levels and spacer length equal to stock. You'll have 2" more air gap to play with oil levels and the fork will react a bit less severely to minor changes in oil level, so it will be a bit more tunable.
    I wouldn't advise moving on until you've exhausted all that is possible via oil levels and weights using the stock internals.
    Too many variables to rely on what works for someone else.
    Just my .02. If you don't roll with the stock internals at first you'll have no basis for comparison and will probably spend a ton of money, then not be sure which change to undo.
    If you just gotta spend munny you should probably go straight to emulators and go through the learning curve with them, instead. Same procedure but with more clear benefit.
    Same procedure. Leave the longer, shorter, stiffer or progressive springs and gizmos off your charge card until you find you actually need them.
    SW Ohio
    19
    Ok thanks. Thats what I figured. Im definitely not looking to throw any more money at this thing than I have to. Just couldn't help thinking "what if" while it was apart.
    Btw Im giving the shinko 421 trials tire a try based on your initial impression of it. Its gotta be better than the bald, dry rotted stocker.
    Desert, SoCal
    7,369
    Cool. Let us know how that works out. We're not piling up the miles on hers as quickly as we'd hoped. I'd like to see how they wear.
    I hope I didn't come off as discouraging experimentation, cuz there's plenty of room for that. But I'll bet you that no more than 1 in 10 TW's even have oil from this decade or at the proper levels and their owners have no clue how well it can be made to work. I guess my point is that you gotta start somewhere.
    Senior Member tw200sgp's Avatar
    Mar 2012
    Singapore
    258
    I'd second Lizards view. I changed the oil and seals in my forks and jammed an additional 1/2" spacer (PVC) in there, changed the steering bearings and wow - it's like a different bike.
    SW Ohio
    19
    Yeah my fork oil came out like sludge. Im doing the steering bearings too, they were really notchy. Worst of all though, was that there were several spokes missing from the back wheel. It wobbled pretty bad in the turns.
    Senior Member joedirt1970's Avatar
    Cardiff by the Sea, CA
    1,345
    I learned that when my money tree starts to blossom that I will need some progessive springs for the hybrid forks. My TDub just didn't handle the triples as well as I had hoped. The Blaster shock needs to be stiffened up too.
    Hidden Content [/IMG]It's not why, but why not. Do it for the right reason now, versus the wrong reason later.
    Born on a Honda Z50, '78 YZ 80, '79 Husky WR 250
    2008 TDub--Jimbo Shield, Lizard Oil Cooler, Blaster Shock, YZ Hybrid Forks, Supermoto front fender, ATV Bars, Acerbis Brake Cover, 1460 Pelican Case, Cycle Rack, Power Core, Gold Chain.
  1. $1600 for a pair of YZ80 forks...
    By Trikstr in forum General Discussion
    Last Post: 04-27-2013, 09:23 PM
  2. YZ80 fork input needed
    By pgilles in forum Performance and Customization
    Last Post: 11-08-2012, 04:22 PM
  3. YZ80 Forks Question
    By old betsy in forum Technical Help
    Last Post: 10-14-2012, 04:59 PM
  4. Replies: 5
    Last Post: 05-03-2012, 11:23 AM
  5. YZ80 Fork discussion revisited
    By abyssdncr in forum Performance and Customization
    Last Post: 11-18-2010, 01:50 PM
how to get apart front forks on yz80
yz80 forks
yz80 stock viscosity
