Carb help
Results 1 to 2 of 2
Thread: Carb help
    Junior Member Fatbez's Avatar
    1
    Hi I'm new here, I've recently bought a 1991 tw200 and am having trouble getting it running right, the bike had been sat for a while and the tank had gone quite rusty, so have cleaned this out, then removed the carb and cleaned this too. Now I can't get this back on.
    The air inlet hose will not fit back on.
    I have read that this often shrinks as it gets old, so I may need a new one, my problem is I'm in the uk and parts for tw200s are quite rare, does anyone know if tw125 shares the same air box and inlet hose? Or have an bright ideas?
    Thanks
    Adam
    Desert, SoCal
    7,369
    Most of us are from elsewhere, in places where the 125 has never been available.
    Makbig will know.
  1. Is the OEM carb a Mikuni carb?
    By macbig2k1 in forum Technical Help
    Last Post: 01-29-2013, 05:50 PM
  2. Newer CV carb vs. older carb. MPG
    By number356 in forum Technical Help
    Last Post: 03-28-2011, 11:25 AM
