Tool Box
Results 1 to 10 of 11
Thread: Tool Box
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    I've been very careful to get my on board tool kit down to a minimum, But I'm planning a trip for next summer that will be long enough that an oil change will need to be done along the way. I'll want to carry a few extra tools along for that and other things. I already had an old tool box from a Honda ATC90 in my plunder, so I decided to put it to use. 99% of the time it will be empty, but when I need it I'll be happy it's there.
    Spokane, Washington
    17,257
    Nothing wrong with that at all, except it's too clean!
    1st John 1:9
    John 3:16
    John 3:17
    Sep 2011
    2,431
    I'll fix that tomorrow! It was black and cruddy, but I hit it with some Rustoleum metallic silver, it's a pretty close match for the frame now.
    Senior Member FortPayne's Avatar
    Nov 2011
    Alabama
    326
    Looks good! Are you offroading with it mounted?
    Tenaciously Deviant Unwittingly Brilliant
    Sep 2011
    2,431
    I'm not an aggressive rider and almost all of my riding in on dirt and gravel roads, or abandoned roads and logging trails. Not a lot of real off road riding is available here. The pictures make it look larger than it really is, it's only 6" long and 2 1/4 in diameter. I'm not concerned with any clearance problems, it's 11" above the ground and if it does get bashed, I've got another one
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Good thinking.
    Sep 2011
    2,431
    Thank ya sir, I've ran some pretty rough trails for the last two days trying to find a problem with it, I can't find one. Not even a rock chip on the paint
    Senior Member patrick007's Avatar
    Jan 2013
    Red Deer, Alberta Canada
    112
    I like it, looks good.
    Sep 2012
    Northwestern Oregon
    1,092
    Let's see what is INSIDE your tool kit.
    Sep 2011
    2,431
    I carry a shortened 3/8 drive ratchet, two 2" extensions, 8mm, 10mm, 12mm sockets in the front tool carrier. To the stock tool kit I've added a 5mm allen wrench, and a 19mm box end, I replaced the stock pliers with needle nose vice grips. I know the factory screw driver is cheesy but I left it in just in case, I've changed all the phillips head screws to allen head or 8mm head so I should never need the screwdriver.
    I added the 19mm for the axles, you need a 19 and a 22mm for the rear, the factory kit has a 19 and 22mm but they are on the same wrench, kinda makes it hard to hold both sides. And for the front you need two 19mm's.
  1. TW Tool Kit
    By bruisr in forum General Discussion
    Last Post: 09-28-2014, 08:48 PM
  2. Do you have a chain tool that you like?
    Last Post: 06-09-2013, 11:02 AM
  3. tool boxh
    By ridgeline in forum Performance and Customization
    Last Post: 05-30-2013, 01:52 PM
  4. Tool Kit
    By scotti158 in forum General Discussion
    Last Post: 05-14-2013, 03:35 PM
  5. Tool Tube
    By lyfestyl in forum General Discussion
    Last Post: 08-19-2012, 09:00 PM
tool kit
tw200 tool box
