Engine oil cap breather tube replacement
Results 1 to 9 of 9
    Junior Member zil46's Avatar
    May 2013
    6
    Hi guys,I'm new here and in need of any kind of advise.just got this Tw from a friend of mine last week and was surprised that the cap for refilling the oil had a tubing with its end looking like a muffler.it does give out a fair amount of air just like the exhaust.I was told that it acts as a pressure relief to maintain the engine temperature or something like that.it looks cool though but will take it out if its doing any damage to the engine.another concern is,will I lose any kind of compression?
    Kinda cool ain't it...
    Senior Member patrick007's Avatar
    Jan 2013
    Red Deer, Alberta Canada
    112
    It looks like a oil catch can, it acts the same way as pvc valve/breather. Mainly it is just for looks, alot of people do this to scooters ie: Honda Ruckus (do a search if you want). I would just buy a different oil cap like I did, check "Rocky TW'S custom build". I like your header pipe looks to be ttr 225. Congrats on your new toy.
    Aug 2011
    Cayce, SC
    3,109
    I have used uni filters in the past to replace the crank case breather hose. You can hear the internal of the engine much more distinctly doing this. I do have to say that while it really is pretty useless it does look kinda trick.
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    May 2013
    6
    Thanx man...really appreciate it..
    Apr 2013
    Central Iowa, USA
    310
    Does having a relief on the oil cap gain you anything over using the stock breather tube from the crank case to the airbox? I'm just curious.
    1993 TW200
    May 2013
    6
    Well if u ask me,im not too sure myself.maybe someone could help us?pinned?im just concern now if I'm losing any kind of compression from the engine by using this coz there's a fair amount of air that's coming out..
    Desert, SoCal
    7,369
    Every time your piston goes down air is expelled, and time it goes back up aa certain amount will be drawn in.
    Your little gizmo won't neccesarily cause any problems as long as you never plan to cross water, but if you still have a stock airbox it is a pointless accessory and not nearly as smart or functional the stock vent routed to the airbox. I'd get rid of it and reconnect the vent to the airbox.
    W
    May 2013
    6
    Wow,that's help.will do it then.thanx man..cheers.
    Jun 2011
    AZ
    793
    I just got a clear high pressure hose connected it to the crank shaft vent aka blow by ,routed it under the seat and all the way to the license plate and the end I put a collar on and a small K&N breather filter.
  1. TW tube size?
    By retro in forum Technical Help
    Last Post: 06-25-2013, 08:42 PM
  2. Breather tubes
    By nfpgasmask in forum Technical Help
    Last Post: 01-10-2013, 03:21 PM
  3. FS: New inner fork tube
    By apodhajski in forum TW200 Classifieds
    Last Post: 03-23-2012, 03:29 PM
  4. Battery breather hose
    Last Post: 07-06-2011, 06:12 AM
  5. OEM tube is $80!!! Must be aftermarket available???
    By unclejemima in forum General Discussion
    Last Post: 02-27-2011, 03:58 PM
what do you gain from a oil cap breather
