TW200 BRAT
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 58
Like Tree7Likes
Thread: TW200 BRAT
    Member tuhinuhi's Avatar
    May 2013
    Sydney, Australia
    93
    Hey
    I purchased a 94 tw200 about 2 weeks ago and since then have been researching about turning it into a jap style street tracker.
    Living in Sydney, the Deus shop have sparked me with the motivation try tackle a custom myself. As the shop probably does to most people.
    Here are some photos.
    Haven't done much as of yet besides research and ordering some parts.
    I have an extended swing arm, brooklands fender, fender eliminator, new chain and some grips on the way from japan.
    I'm about to purchase a air box removal kit which will reduce the size of the battery. Which means to start the bike I'm going to have to use the kick start, which i have a bit of trouble with at the moment.
    It kicks fine when its warm but when cold i cant get it started, do i just require persistence and power?
    Here is a photo of my carb, i've looked in the manual but cant find out what the red pull does im sure its associated with the kick start but what is it called and exactly what does it do? (sorry about the poor image quality)
    Should be a few weeks before the parts from japan arrive but will update as often as possible.
    Thanks a lot
    Harry.
    Nov 2011
    norcal nutjob
    3,305
    not sure about the red plug, mine has it too... in black. deus makes some sick looking bikes, no lack of inspiration from them.
    btw: your color scheme corresponded to 1995 in the states.
    ride on!
    Apr 2013
    Central Iowa, USA
    310
    Looks like a clean TW to start with, so it should be a fun project.
    I have a USA 1993 model. That red plug area on yours is a plugged hole on mine.
    1993 TW200
    Senior Member mrbracket's Avatar
    Jul 2012
    Springtucky, Orygun
    631
    Sounds like a very fun project! I like the look of the hollow mods My non-California 1994 model does not have that red plug in the carb???
    You've got a friend in the Bracket Business! Hidden Content
    Get your TW200 Parts at ProCycle! Hidden Content
    Sep 2011
    Southcoast MAsshole
    2,661
    is that red pull on the carb a hot start pull?
    https://tw200forum.com/forums/50731/ShowPost.aspx
    and welcome
    Desert, SoCal
    7,369
    The red knob is an air bleed. It allows you to lean your mixture at higher elevations. It works in a manner opposite that of the choke.
    The passage for it is not machined on U.S. models cuz the EPA is cool with polluting stuff at or above treeline?
    Jun 2011
    AZ
    793
    Quote Originally Posted by tuhinuhi View Post
    Hey
    Thanks a lot
    Harry.
    You need a high capacity condenser if you go without a batter. Daytona a Japanese company sells it in Japan called a Battery lesser.
    May 2013
    Sydney, Australia
    93
    thanks guys, will post my progress
    May 2013
    Sydney, Australia
    93
    Some parts have arrived.
    Still waiting on an air box eliminator kit, Service manual and some bridge stone tw203 and 204.
    Once these other packages come i can start the tear down.
    Merlin2408 likes this.
    Senior Member patrick007's Avatar
    Jan 2013
    Red Deer, Alberta Canada
    112
    Looking good can't wait to see the end of it all
battery lesser daytona high capacity condenser
brat style tw200
brooklands tw200 rear fender
lizrdcooler yamaha xt225
nitro heads tw200
turning a tw200 into a bobber
tw 200 street tracker
tw200 bobber kit
tw200 bobber kits
tw200 brat
tw200 brat style
tw200 forum fender eliminator
