tool boxh
Results 1 to 10 of 12
Thread: tool boxh
    Member ridgeline's Avatar
    Jun 2012
    dartmouth nova scotia 2010 tw200
    84
    here is a little tool box that fits between the cyclerack and the rear fender it is bolted to the rear fender using the three holes that hold the black rubber pad to the fender i used longer stainless steel bolts it is 10 inches wide by 7 inches long by 2 inches high this is what it holds tie wraps vise grips tire irons first aid kit and a small rachet set it is mad from aluminum
    Senior Member patrick007's Avatar
    Jan 2013
    Red Deer, Alberta Canada
    112
    What series is that pelican case?. Can you take a picture further back
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    Very nice! Best use of the empty space I've seen, good job.
    Jun 2012
    84
    rocky tw here are the pictures you wanted thanks r80rt it worked out pretty good you cant even tell its there with the pelican box there
    Sep 2011
    2,431
    Of course you know I'm gonna steal the idea
    Jun 2012
    84
    help yourself my rack may be higher i had to raise it a 1/2 inch when i did the toyanvil storage tube mod to clear my signal lights glad you like it
    Senior Member howardgene63's Avatar
    Mar 2012
    central missouri
    234
    Nicest tool box setup I've seen yet. I,ve been looking for an alternative to the plastic tool tubes everyone uses.
    Sep 2012
    Northwestern Oregon
    1,092
    ridgeline - great idea for using the wasted space - I think you could be a candidate for a Mr. Gizmo award.
    Senior Member joedirt1970's Avatar
    Cardiff by the Sea, CA
    1,345
    That's a good lookin' TW there eh?
    Hidden Content [/IMG]It's not why, but why not. Do it for the right reason now, versus the wrong reason later.
    Born on a Honda Z50, '78 YZ 80, '79 Husky WR 250
    2008 TDub--Jimbo Shield, Lizard Oil Cooler, Blaster Shock, YZ Hybrid Forks, Supermoto front fender, ATV Bars, Acerbis Brake Cover, 1460 Pelican Case, Cycle Rack, Power Core, Gold Chain.
    Jan 2013
    112
    Thank you for the pictures. That pelican case sits pretty good on the rack, I have yet to buy a cyclerack just toying around witth the idea of a opelican case as well. Looks like you might have fabricate some tool boxes for us TW owners.
  1. TW Tool Kit
    By bruisr in forum General Discussion
    Last Post: 09-28-2014, 08:48 PM
  2. Do you have a chain tool that you like?
    Last Post: 06-09-2013, 11:02 AM
  3. Tool Box
    By r80rt in forum Performance and Customization
    Last Post: 05-27-2013, 12:02 PM
  4. Tool Kit
    By scotti158 in forum General Discussion
    Last Post: 05-14-2013, 03:35 PM
  5. Tool Tube
    By lyfestyl in forum General Discussion
    Last Post: 08-19-2012, 09:00 PM
