I Got a Lizrdbrth oil Cooler!
Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Like Tree1Likes
Thread: I Got a Lizrdbrth oil Cooler!
    Senior Member r80rt's Avatar
    Sep 2011
    2,431
    Got my Genuine Lizrdbrth oil cooler today! Man is this thing nice. I pestered him in to selling me a Cali kit and I made up my own mount. I'm a function over form kind of guy, so my mount wouldn't please every one.
    I'm about as happy as one man can be. Thanks Russ, I appreciate the work you've put in to make us a cooler, and my motor thanks you too
    Mar 2012
    Boonville, No.-Calif.
    1,357
    Looks great! You gunna like it! m.
    May 2012
    Tucson, AZ
    976
    Man, I'm so jealous!
    2012 KLR650
    - Sold
    2013 Tiger Explorer XC
    2014 CB500X - RRP L3
    Sep 2011
    2,431
    It's absolutely the best thing I've done for, and to my TDub. I plan to ride this bike for a long time, the cooler will help make that happen.
    Senior Member B-dub's Avatar
    Jul 2011
    Southwest Utah
    2,132
    Nice job with the installation. It looks impressive; I like how you routed the lines.
    Nov 2011
    norcal nutjob
    3,301
    right on r80rt!
    you've been talking about this addition for a long time, congrats on finally getting it!
    i got mine a couple of months ago, and finally got around to putting it on, a great addition.
    three CHEERS for señor LIZRDBRTH for all his work making it happen!
    Member ridgeline's Avatar
    Jun 2012
    dartmouth nova scotia 2010 tw200
    84
    great job it looks good your pretty good at improvising
    Sep 2011
    2,431
    I've had a couple of questions on my install, so I'll try to tell how I made the mount. First I got a 1 1/2" muffler clamp, the U bolt that came with it was to short so it wasn't used. I went to a hardware store and got a U bolt that was long enough to work. I painted the U bolt and bottom half of the muffler clamp to match the frame, I used Rustoleum Metallic silver paint, it's very close to the frame color. Then a thin strip of rubber between the mount and the cooler for a cushion. It's bolted up with stainless steel washers and nylon lock nuts. Here is a look at how it worked out, it's a solid mount and clears everything. Roughly $7 invested and about 30 minutes to do. I hope this helps, but I'd still advise waiting on the 49 state kit,
    When Lizrdbrth perfects his 49 state mount I'll be first in line to get one, I'm sure it'll be light years ahead of this
    Junior Member seantx's Avatar
    Feb 2013
    waco, tx
    28
    Does the Cali kit include the oil filter adapter and the actual heat exchanger? What did you have to buy other than the clamp?
    05 TDub
    01 VFR
    Sep 2011
    2,431
    Search the forum for lizrd cooler, you'll find what you need.
    https://tw200forum.com/index.php?/top...r-lizrdcooler/
  1. Oil Cooler capacity?
    By Grant in forum Technical Help
    Last Post: 06-24-2013, 03:11 PM
  2. OIl cooler questions.
    By Dako124 in forum Technical Help
    Last Post: 06-08-2013, 10:54 PM
  3. oil cooler mounts
    By Dako124 in forum Performance and Customization
    Last Post: 05-16-2013, 09:57 PM
  4. Oil Cooler
    By chuck in forum Technical Help
    Last Post: 08-07-2012, 03:55 PM
  5. Oil Cooler
    By Hobopoet in forum Performance and Customization
    Last Post: 02-13-2011, 09:36 PM
cover filter oil xt225 with oil cooler
lizrdbrth
lizrdbrth cooler
lizrdbrth oil cooler
lizrdbrth oil cooler tw200
lizrdcooler
tw200 oil cooler
yamaha tw200 lizrdbrth oil cooler
