LED Lighting
Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By liquidsilver
Thread: LED Lighting
    Senior Member liquidsilver's Avatar
    Oct 2010
    SW Washington
    104
    Parts List
    2 LED strips from Ebay $15 delivered
    22" clear tubing
    1 metal strip 22"x0.4"x 0.1"
    2 Zip ties
    Wire Connectors
    Time required 20 minutes
    Difficulty: Novice / Beginner
    I have some new front lights coming from a forum member to replace the one that's damaged. While waiting, I thought I'd try some LED's on there. I like them and will probably mount a second set on the mirrors as turn signals. No need for a flasher relay as long as the rear stays filament based.
    Cut metal strip to desired length. Take care to note whether your state has specific requirements for signal separation.
    Remove protective tape from back of LED strips and attach LEDs to ends of metal strip.
    Cut tubing into two equal pieces and slide over the ends of the metal strip allowing leads to exit tube from center point on metal strip.
    ZipTie the tube-enclosed strip to the desired mounting point.
    Splice leads into existing turn signal wiring for marker lights.
    Repeat process for signal lights if desired.
    The tubing acts as a diffuser and doubles as a protective coating for the LEDs.
    Another fine redneck fix from LiquidSilver
    chris209 likes this.
    Richard (a.k.a. LiquidSilver)
    __________________________________________________ ________________________________________
    91 TW200 aka "The Mule" :-)
    03 VRSCA / 05 Polaris Sportsman 500 / Honda Helix CN250[/color]
    Senior Member dganey's Avatar
    Oct 2010
    SE Michigan
    341
    bright lights and cost effective to boot. Nice job.
    Senior Member LittleCowTW's Avatar
    Portland, OR
    152
    Thats pretty slick. Nice work! Maybe some rubber stoppers as watertight endcaps?
    Persistence is the better part of genius.
    Oct 2010
    SW Washington
    104
    I thought about using rubber stoppers or possibly some Silicone sealant .
    I have the same light strips on another bike around the license plate. They seem to do just fine even with a little water on them. We'll see how long they last.
    Oct 2010
    SW Washington
    104
    Update... Turn signals added to mirrors after old lights removed.
  1. LED / HID Lighting
    By Henrici in forum Technical Help
    Last Post: 08-31-2013, 06:17 PM
  2. led accent lighting
    By PalmStateCrawler in forum Off-Topic
    Last Post: 11-06-2011, 06:07 PM
  3. hid lighting
    By dizzle2 in forum Performance and Customization
    Last Post: 06-24-2011, 11:56 PM
  4. LED lighting
    By chevyluver in forum Technical Help
    Last Post: 01-08-2011, 12:19 PM
  5. Auxillliary Lighting
    By bigdreama in forum General Discussion
    Last Post: 09-18-2010, 01:12 PM
accent lights
tw200 hid
tw200 led
tw200 led lights
