Carb Work
Results 1 to 2 of 2
Thread: Carb Work
    Junior Member jakemistake's Avatar
    Way Out West
    16
    Been working on my carb (TK carb), here's what I done, maybe you guys/gals have some experiences that have worked good? Lets hear them! 1) Shimmed the needle jet by .030, helped quite a bit. 2) Turned the front air screw out to one turn, cured the hesitation at low speed. Still get a little hesitation at 45-50 miles per hour. Will adjust the float level and see what happens. What else is there left to do? Any ideas?
    When in doubt, Gas it!
    Senior Member davidsonsgccc's Avatar
    chickamauga, Ga.
    190
    check the old archives there is alot of very good info on carbs jetting and such.
    not a TW owner but i play one on this forum.
  1. '94 Carb Work
    By Omega Man in forum Technical Help
    Last Post: 06-03-2013, 07:42 PM
  2. Painful Day at Work
    By cptrout in forum Off-Topic
    Last Post: 12-04-2012, 06:26 PM
  3. First ride to work......
    By kenfyoozed in forum General Discussion
    Last Post: 09-28-2012, 01:51 PM
  4. Can't get right after Carb work
    By SURVEYWATERS in forum Technical Help
    Last Post: 03-29-2012, 04:49 PM
  5. Carb work
    By 805gregg in forum Performance and Customization
    Last Post: 02-18-2011, 08:18 AM
