Aftermarket Headers?
Results 1 to 4 of 4
    Member Alexander's Avatar
    Aug 2013
    Washington State
    70
    Hey guys
    Has anyone else wanted to replace that painted steel header? I sure would love to
    Does anyone make aftermarket headers for the TDub?
    Please post with any header options you may know of. Thanks TW fans
    Senior Member mtkd's Avatar
    Feb 2012
    NY
    215
    If i am not mistaken the xt225 header fits and it isn't painted. I would double check that though. Post 2253 has the picture.
    The Yamaha TW200 Thread... - Page 151 - ADVrider
    -Szj
    2001 TW
    Senior Member tinman tim's Avatar
    Jan 2012
    northeast ohio
    503
    precisely right mtkd. The pipe is stainless steel. It will need to be cut to fit the TW however. About 3/4" off the muffler end, and its a direct swap. Happy modding, TIM
    Desert, SoCal
    7,369
    Here's one that I polished up for the wyfebyke. They're pretty cheap used.
    Make sure you get the heat shield. TW shield won't fit them.
  1. Aftermarket seat
    By Dako124 in forum Performance and Customization
    Last Post: 05-31-2013, 02:53 PM
  2. For those of you with aftermarket exhaust
    By xdac in forum Technical Help
    Last Post: 03-02-2013, 07:12 PM
  3. Aftermarket ignition
    By Jrx300 in forum Technical Help
    Last Post: 09-17-2012, 01:58 AM
  4. aftermarket forks
    By handikapsk8r in forum Performance and Customization
    Last Post: 05-13-2012, 09:23 AM
  5. OEM or Aftermarket
    By thumper in forum General Discussion
    Last Post: 10-20-2010, 10:31 AM
yamaha tw200 aftermarket header
Tags for this Thread
