'92 XT225 parts that fit so far...and some that don't.
Results 1 to 6 of 6
    Senior Member Trikstr's Avatar
    Jun 2012
    Oak City, UT
    156
    I really only wanted 2 things off this bike.
    Gas tank-rusted out.
    Engine/Trans. needs rebuilt but knew that. It will end up in my '99 sometime.
    Speedo/Trip meter looks like a direct swap. Instrument lights different. Mounting bracket has different hole spacing.
    Stainless head pipe looks like it'll fit. Muffler looks similar. Have to check bends. Has a nice stainless heat shield.
    Turn signals-Fronts same length as TW. Rears shorter should fit under and be protected by CycleRack.
    Front fork tubes are larger diameter.
    Rear shock different.Has linkage system.
    Rear brake arm 1/2" longer.
    '99 TW,Ricochet skid plate, Seat Concepts, Jimbo shield, 2" extended swingarm w/Maxxis Bighorn, 5.10 Kenda K270, Stealth exhuast, YZ80 hybrid front forks w/HyperPro proressive springs, ProCycle high mount front fender, ProCycle wide foot pegs, TT-R stainless head pipe, Lizrdbrth cooler, D-Flex hand guards, XT350 gas tank.
    2002 Honda Spirit Shadow VT750
    1987 BW350
    '78 Honda XL100
    Desert, SoCal
    7,369
    How many wires on the CDI? I've always suspected the early XT's could be possible CDI donors for the '87 TW's. Never had my hands on one.
    Jun 2012
    Oak City, UT
    156
    I'll have to check.
    1987 BW350
    '78 Honda XL100
    Jun 2012
    Oak City, UT
    156
    10 wires.
    1987 BW350
    '78 Honda XL100
    Desert, SoCal
    7,369
    Quote Originally Posted by Trikstr View Post
    10 wires.
    My bad. Not sure what I was thinking. It was the early '80's XT200's which may share CDI's.
    Though it may work in an '88-00 TW. The wire count is right.
    Jun 2012
    Oak City, UT
    156
    Update on a few parts.
    Muffler won't fit. Bends are wrong.
    Front fork tube diameter is 35.9 mm. TW-32.9 mm. Axle bolt is slightly smaller could be drilled and re-tapped for TW if someone wanted to convert. More travel, disc brake and drains. Not sure if triple tees would be a direct swap.
    Kickstand will fit. About an inch longer.
    CDI has same # of wires as my 99, but plugs are different.
    1987 BW350
    '78 Honda XL100
  1. XT225 Tank
    By r80rt in forum Performance and Customization
    Last Post: 05-09-2016, 03:57 PM
  2. Is the XT225 swing arm the same?
    By randucci in forum Performance and Customization
    Last Post: 08-04-2013, 11:21 AM
  3. XT225
    By harvey in forum General Discussion
    Last Post: 08-20-2012, 12:19 AM
  4. XT225 clutch in a TW200
    By GoNOW in forum Technical Help
    Last Post: 11-24-2011, 01:24 AM
  5. TW200 or XT225
    By ckahleer in forum General Discussion
    Last Post: 02-20-2011, 09:14 AM
93 xt225 fit 99 xt225
xt225 engine mount
xt225 gas tank that fit
