Kolpin gas can L-Bracket to Cyclerack mounting tips/tricks?
Results 1 to 8 of 8
    Member n8bone's Avatar
    corn desert, IL
    46
    Hi,
    I did a search for mounting the Kolpin gas can L-bracket to a cyclerack and found this thread but most of the pictures are gone. I'd very much like to see some, please.
    Especially, I'm wondering if anyone has successfully mounted theirs down and off the left side in a saddle-bag type position. (like this Suzuki) I'm thinking some triangulation support will be necessary to be secure but having it there would seem to be low and out of the way.
    thanks in advance,
    n8
    Hidden Content : KLR pegs, 47t sprocket, cyclerack, Bridgestone 203/204, D.I.D. o-ring chain, Jimbo shield
    Hidden Content : gone to a new home. it was my first...had it for 14 years. miss it sometimes.
    Senior Member rm_hm's Avatar
    1,619
    That side mount is cool. I'd be interested in a how to too. I can't mount on back since I did the big led brake mod.
    Senior Member HenryJ's Avatar
    Oregon, USA
    184
    Upright rear mounted:
    One stainless steel u-bolt around the top bar with a 1/2" rubber spacer holds it securely in the upright position.
    "Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
    "Speed is just a matter of Money - How fast do YOU want to go?"-Mechanic from Mad Max-
    If at first you don't succeed - Don't take up Skydiving!
    - Hidden Content
    Member JerryT's Avatar
    crossville, tn
    86
    longroof has one mounted on the left side. I think he fabbed the mount himself. Maybe he will see this and post some pictures and detales of the mount.
    Senior Member flingwing1969's Avatar
    Apr 2012
    Shasta County - In the Shadow of Lassen Peak
    374
    Quote Originally Posted by JerryT View Post
    I know this is a long-dormant thread, but it deserves to be continued as there are those amongst us who will find this information useful. Thus this reply.
    CycleRack has modified their pannier system to accommodate an inside mounted Kolpin Fuel Pack Junior that can work with your bags still on. Since I'm our and about on my property and because I'm about 15 miles from the nearest station, additional fuel is a real plus. Here is what I did.
    This is the pannier mount with the Kolpin can attaching point. It is actually only a small piece of sheet metal, drilled for bolts, bent with a 90 degree lip bent on with a break of some type, and this is welded to the inside of the bag plate on the pannier attachment. Here it is mounted on my T'Dub:
    This is what $38.35 gets you at Amazon:
    The set from Kolpin comes with self-tapping screws that won't work here, bolts are in order, with washers and lock-nuts.
    Marc at CycleRack said the new unit was predrilled to fit the Kolpin mounting plate, but I found I had to modify it so that the second bolt would fit - just a quick drill-out. Since everything had already been mounted, I drilled the hole by feel (would have had to have in any event since the tank mount plate sits behind the bag mount. Here she is:
    Here's the tank mounted:
    You might think that the fit is kind of close, making it a pain to get the tank off but CycleRack's pannier system is easy to tip up on the rack permitting very easy access:
    Frosty Hollow
    13,166
    Quote Originally Posted by Flingwing View Post
    Good info, thanks for posting. Though I've put a larger gas tank on my TW, I'll be wanting some extra fuel when I ride my "Big Loop" ride next summer. You've solved it for me.
    Oregon, USA
    184
    ... I've put a larger gas tank on my TW, I'll be wanting some extra fuel when I ride my "Big Loop" ride next summer...
    Yup, the bigger tank helps for sure, but you still need that extra gallon to get the range for those long waits between fuel stops. With the Clarke and Kolpin along the range is good enough to keep up with the KLR.
    - Hidden Content
    Senior Member Trikstr's Avatar
    Jun 2012
    Oak City, UT
    156
    Mounted mine to the back of Cyclerack using 2 u-bolts and 2 3/4" conduit clamps. Went for a ride and it was making noise due to bumps. Cut up an old tube and placed some rubber between L-bracket and rack and inside conduit clamps. No more noise.
    I mounted the Kolpin gun scabbard on the left side of the rack with L-bracket with 4 U-bolts. Haven't tried it out yet.
    '99 TW,Ricochet skid plate, Seat Concepts, Jimbo shield, 2" extended swingarm w/Maxxis Bighorn, 5.10 Kenda K270, Stealth exhuast, YZ80 hybrid front forks w/HyperPro proressive springs, ProCycle high mount front fender, ProCycle wide foot pegs, TT-R stainless head pipe, Lizrdbrth cooler, D-Flex hand guards, XT350 gas tank.
    2002 Honda Spirit Shadow VT750
    1987 BW350
    '78 Honda XL100
  1. Mounting Kolpin or similar tank horizontly
    By bikerjosh in forum Performance and Customization
    Last Post: 11-26-2012, 10:42 PM
  2. Kolpin Fuel Pack Jr. Mounting Options
    By Kankujoe in forum General Discussion
    Last Post: 03-06-2012, 04:32 PM
  3. mirror mounting bracket....screws
    Last Post: 06-17-2011, 12:37 PM
  4. Brand new Kolpin Fuel pack/bracket kit
    By mga60tw in forum TW200 Classifieds
    Last Post: 01-25-2011, 06:44 PM
  5. Mounting Watertight Case on Cyclerack
    By Lewis54 in forum Performance and Customization
    Last Post: 09-18-2010, 04:39 PM
5l gas can for tw200
cutting up a pannier to accomodate a gun scabard
dr-z 400s rifle scabbard
fuel cans yamaha tw200
gas can for tw200
kolpin gas can mount
tw200 extra fuel
tw200 fuel can
tw200 fuel cyclerack
tw200 gas can
tw200 kolpin gas
yamaha tw rack gas holder
