handle bar guard problems
Results 1 to 10 of 16
    Senior Member Dmd3058's Avatar
    Jul 2011
    Pittsburgh Pa
    144
    handle bar guard problems (solved with pictures)
    i bought some handle bar guard protectors (MSR) , the left side fits fine. but the right side dont fit it seems that the front brake lever is to long, we even tried to move the lever, kill switch down some so it would fit, but sill no luck. anyone else have this problem, how did you fix it? thanks in advance
    fixed the problem
    the knob had to be cut off, i cut mine with a sawzall but you could use a cut off wheel im sure. then i used a grinder and wire wheel to smooth the end.
    now i have a question for those of you who know more about the front brakes then me. the hose that is attached to the master cylinder can that be loosened and adjusted easily or will i get air in the lines? i need i to be more up and down rather than the angle it is currently at because i have to rotate the guard upwards because if i do go down the brake lever is below the guard and could brake off, but i cant make no adjustments with the brake line in its current position. thanks in advance
    Senior Member kdick91's Avatar
    Sep 2012
    TX
    188
    I had the same problem with my cheap-o's off eBay. I ended up loosening the reservoir and handle assembly and moving it inwards about 1/4" to 1/2". Not much at all, but enough to clear it.
    Gone - 2006 TW200
    Gone - 2014 CB1100
    2015 WR250R - Bored, stroked
    Gone - 2000 Trans Am
    Stolen - 2007 Trailblazer SS
    2014 Jeep Grand Cherokee SRT
    1977 Steyr-Puch Pinzgauer 710M
    2 Timothy 1:7
    Jul 2011
    Pittsburgh Pa
    144
    Quote Originally Posted by kdick91 View Post
    yea i tried that, still didnt work.. i even got them from the local yamaha dealer
    Sep 2012
    TX
    188
    Quote Originally Posted by Dmd3058 View Post
    Is it possible you have non-OEM levers on your bike?
    Gone - 2006 TW200
    Gone - 2014 CB1100
    2 Timothy 1:7
    6,955
    I added a few washers to open it a little more.
    If yours has a metal bar going through it you might have to bend it to fit.
    Jul 2011
    Pittsburgh Pa
    144
    i bought the bike brand new from the dealer, so im pretty sure they are stock as i have never changed them
    Jul 2011
    Pittsburgh Pa
    144
    mine is all metal with plastic that screws on but i will have to give the washers a try ... thanks for your 2¢
    May 2012
    Tucson, AZ
    976
    My front brake lever didn't fit my Tusk D-flex guards either, but it was bent anyway so I took a hacksaw to it and turned it into a "custom" shorty lever. Clears with room to spare now!
    2012 KLR650
    - Sold
    2013 Tiger Explorer XC
    2014 CB500X - RRP L3
    Senior Member tcepilot's Avatar
    May 2013
    Dayton Ohio
    765
    I just tured my entire lever assemblies down a bit so they dont hit the plastic on my moose racing guards
    -tcepilot Hidden Content
    --- Psalm 23 Verses 4-5 ----
    Even though I walk through the valley of the shadow of death, I fear no evil,
    for You are with me; Your rod and Your staff, they comfort me.
    You prepare a table before me in the presence of my enemies; You have anointed
    my head with oil; My cup overflows. (New American Standard Bible)
    Jul 2011
    Pittsburgh Pa
    144
    updated with the pics
  1. Raising The Handle Bars
    By RikR in forum Performance and Customization
    Last Post: 08-17-2013, 12:52 AM
  2. Stupid Handle Bar Question...
    By bsullivan161 in forum General Discussion
    Last Post: 05-21-2013, 12:42 PM
  3. handle bars
    By ridgeline in forum General Discussion
    Last Post: 05-19-2013, 10:36 PM
  4. Handle Bars?
    By Woodi23 in forum Performance and Customization
    Last Post: 11-22-2012, 09:15 PM
  5. Can TW handle 2 riders?
    By JerryW in forum General Discussion
    Last Post: 04-29-2011, 05:37 PM
