TrailTech Dashboard Indicator Wiring - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Like Tree5Likes
Thread: TrailTech Dashboard Indicator Wiring
  1. #11
    Senior Member Till Death Dual Us Sport™'s Avatar
    Jan 2018
    Corona, CA
    234
    Quote Originally Posted by Ice_Man View Post
    Thought Id bring this tread back to life. I've since wired everything up (turn signal indicators, high beam, etc), however I still can't determine which wires to connect to the "neutral" light on the TrailTech indicator (just a single LED light with two wires) to the bike wiring harness. I have tried a few different combinations using a common ground and either get nothing or end up blowing a fuse. Should I be doing something different, possibly a different ground? I tried looking at the Yamaha wiring diagram for the bike and can't really figure it out that way either. Any help would be appreciated.
    I've been working on mine for 2 days and can't figure it out! I've blown 8 or more fuses, sparks, and a bit of smoke. Horrible experience with this product. Looks like I might have to spend more money (and possibly cancel Moab because of it) and take it to a shop.
    Till Death Dual Us Sport YouTube Channel
    Stickers Available Through Link Below!
  2. #12
    Jan 2015
    Fair Oaks, Calif
    483
    When I installed mine I replaced the existing broken OEM speedo. I did not have any trouble wiring up the turn sig, power etc.. Used a DVM. Bummer that I did not take any pictures of the install. Several of us made our own bracket to hold the Trailtech.
    Yes it does have a resettable trip miles.
  3. #13
    Jan 2018
    Corona, CA
    234
    Quote Originally Posted by jtstdub View Post
    The speedo was fairly easy as it is all plug and play. The dashboard lights, specifically the neutral indicator is what I can't figure out. I also wanted to have separate left and right turn signals but got frustrated and gave up. Right now the six wires coming from the TW are wire nutted and taped up. I'm not a happy camper.
  5. #14
    Jan 2015
    Fair Oaks, Calif
    483
    Quote Originally Posted by Till Death Dual Us Sport™ View Post
    Maybe this drawing might help..... I drew it so I could wire my Vapor.... It was not just a plug and play...hhahaaaa.
  6. #15
    Jan 2018
    Corona, CA
    234
    I don’t see any pic. can you reupload please.
  7. #16
    Jan 2015
    Fair Oaks, Calif
    483
    Are or were you logged in. Can not see pictures if not logged in.
    I can see them..... Here ya go again.
  8. #17
    Jan 2018
    Corona, CA
    234
    I was logged in. Still can’t see the first one you posted but this one I can! Thank you. Going to see if this sheds light on any of my problems.
  9. #18
    Jan 2015
    Fair Oaks, Calif
    483
    Great, now gett'er done and head for Moab!
    Jim
    Dryden-Tdub likes this.
  10. #19
    Jan 2015
    Fair Oaks, Calif
    483
    Did the drawing help a bit. I see that you are using the Trailtec now..... Is everything functioning now?
    Did you know that if the magnet on the hub and the pick-up aligns up the display will not turn off and it will kill the battery in the Trailtec? Just give you a heads up.
    Sure like your videos.. I can ride along with ya!
    Did you make it to Moab?
    Jim
  11. #20
    Jan 2018
    Corona, CA
    234
    Jim
    Still can’t figure out the neutral light. I’m pretty sure the neutral switch went bad. I have a new one ready to install during my next oil change.
    Thanks for the heads up! Good to know.
    Glad you’re enjoying the vids!
    I did not make it to Moab. So many things went wrong after I looped the bike. It ate up all of my Moab funds. Now I have a few stripped valve cover threads on the exhaust side. One is on the bottom so it looks like I’m going to have to pull the engine and install some Time-Serts. I might as well do all 5 while I'm at it.
    Hopefully I have the patience to complete the task
    jtstdub and Darth like this.
  1. WTB indicator lights housing/bezel
    By txarsoncop in forum TW200 Classifieds
    Last Post: 10-29-2013, 08:10 AM
  2. Trailtech vapor on a drum brake (pre-2001) bike
    By jontow in forum Performance and Customization
    Last Post: 03-02-2013, 05:59 AM
  3. Turn signal indicator out?
    By TW200_CA in forum Technical Help
    Last Post: 12-26-2012, 04:54 PM
  4. Wanted-Insterment braket, speedo & indicator box
    By flailer in forum TW200 Classifieds
    Last Post: 04-15-2012, 08:14 PM
  5. Trailtech tachometer install....info needed.
    Last Post: 03-17-2012, 05:27 PM
my tw200 high beam indicater light keeps blowing
trail tech vapor connector identification
tw200 dashboard
tw200 highbeam indcater light keeps going blowing out
tw200 wiring harness lights
