TrailTech Dashboard Indicator Wiring - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Like Tree6Likes
Thread: TrailTech Dashboard Indicator Wiring
  1. #21
    Jan 2015
    Fair Oaks, Calif
    485
    Quote Originally Posted by Ice_Man View Post
    Thought Id bring this tread back to life. I've since wired everything up (turn signal indicators, high beam, etc), however I still can't determine which wires to connect to the "neutral" light on the TrailTech indicator (just a single LED light with two wires) to the bike wiring harness. I have tried a few different combinations using a common ground and either get nothing or end up blowing a fuse. Should I be doing something different, possibly a different ground? I tried looking at the Yamaha wiring diagram for the bike and can't really figure it out that way either. Any help would be appreciated.
    Did you get your neutral light sorted out? If not see if my drawing will help to sort it out?
    Jim
  2. #22
    Senior Member Darth's Avatar
    Nov 2013
    Timbercreek Canyon, Texas
    1,507
    Bummer Dude, bummer...
    Still, I rise!
    Humans: simultaneously capable of such genius and such douchebaggery!
    "Give a Damn"
    - C. M. Howe, Jr.
  3. #23
    Senior Member RaZed1's Avatar
    Oct 2015
    220
    I don't know about the TW specifically, but a lot of indicator lights I've dealt with on various bikes are constant power, floating ground. Meaning the neutral/temp/whatever switch is on the ground side of the circuit, not the power. If the switch only has one wire, it's almost certainly just making/breaking contact to whatever it's screwed into(ground).
    The LED indicators on the Trail Tech also will need polarity observed, unlike the incandescent bulbs on the stock indicator box. Meaning, the negative (input) of the LED gets attached to the constant power, and the positive (output) goes to ground since that's how electricity flows.
    grewen likes this.
  1. WTB indicator lights housing/bezel
    By txarsoncop in forum TW200 Classifieds
    Last Post: 10-29-2013, 08:10 AM
  2. Trailtech vapor on a drum brake (pre-2001) bike
    By jontow in forum Performance and Customization
    Last Post: 03-02-2013, 05:59 AM
  3. Turn signal indicator out?
    By TW200_CA in forum Technical Help
    Last Post: 12-26-2012, 04:54 PM
  4. Wanted-Insterment braket, speedo & indicator box
    By flailer in forum TW200 Classifieds
    Last Post: 04-15-2012, 08:14 PM
  5. Trailtech tachometer install....info needed.
    Last Post: 03-17-2012, 05:27 PM
my tw200 high beam indicater light keeps blowing
trail tech vapor connector identification
tw200 dashboard
tw200 highbeam indcater light keeps going blowing out
tw200 wiring harness lights
