What tire should I use to replace stock front to help avoid washout
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Like Tree1Likes
Thread: What tire should I use to replace stock front to help avoid washout
    Member mtngirl's Avatar
    Hailey, Idaho
    44
    Hey everyone, I am thinking about replacing my stock front tire with something more bitey. I have not yet experienced any washout but will be doing a lot more dirt road/trail riding coming up. Plus, there is quite a bit of sand where I am too. Any thoughts of what to use. I read previously that the Maxxis 6006 was a good replacement in the past, but I don't think they are making it anymore. Thoughts please, thanks tons.
    Member Larrs's Avatar
    Kalamazoo, Michigan
    48
    I believe at smalltires.com they are offering the M6006.
    http://smalltires.com/store.cfm?acti...8&Brand=MAXXIS
    Junior Member Ben Parry's Avatar
    Perth, Western Australia
    9
    Ah,
    the long running tyre question.
    For softer going and expecially sand, avoid going wide with the frint tyre. Narrower tread works a whole lot better... strange but true.
    I use a Pirelli Rally Raid MT21 x 120 wide (it's a rear tyre). What you are looking for is a rear tyre that is not to knobbly and looks like it won't slide sideways so easily. That means you need a nice block pattern around the eadge of the tyre tread. Have a look at the more dedicated off road front tyres and you will get the picture. Folks that have had a ride on my TW comment that the front steers very well and bites well. A 120 section tyre seems to work well, you can go wider of course, but you will pay dear in soft sand...
    Hope you find something you like,
    Ben P.
    Hailey, Idaho
    44
    Quote Originally Posted by Larrs View Post
    Hailey, Idaho
    44
    thanks very much, also for the link!
    Senior Member Petrus's Avatar
    Africa
    458
    Quote Originally Posted by Ben Parry View Post
    ....For softer going and expecially sand, avoid going wide with the front tyre. Narrower tread works a whole lot better... strange but true.
    I agree.
    The "thinner/skinnier" front tires cut into the sand and you can steer the bike. The fatter front tires "float" on the sand and steering is much more difficult.
    Imagine driving on the beach with the front wheel in a tire track that was made by a 4x4 that previously passed that way.
    When you try to get out of the track the front wheel will just follow the groove - like a train on tracks.
    You keep on turning the handle bar to get the front tire out.....
    And then suddenly it does bit into the sand to get out of the track and you`ll go over the handle bars..... unless you were doing it slowly with your feet ready to stabilize the bike.
    I personally think the fat front tire is much more useful on the road than off-road.
    2008 TW200
    Junior Member bser613's Avatar
    South Jersey
    4
    I picked up a Shinko (it says Golden Boy on the side). I went with the 4.10 -18 It's a lil bit smaller than the stock tire. In the sands of South Jersey it performs very well and does ok on the pavement. For the money (34 bucks)
    its the only tire I need for the riding I do.
    Old fat guy on a lil motorcycle
    Junior Member jclovesu's Avatar
    22
    Quote Originally Posted by Petrus View Post
    I agree.
    I've been running the Maxxis 6006 for about 6,000 miles. It's a 130/80-18. If I was going to replace it I would definitely go with a 120. The first time I took the 130 on the pavement through some twisties I was amazed at how much more steering effort it required to get the bike back upright coming out of a corner. Probably due to the heavier tire. I've gone over the handle bars several times trying to get out of ruts. I really can't recommend going over the bars, it's not a lot of fun.
    Tim
    jim
    jim is offline
    Senior Member jim's Avatar
    Indio, CA
    100
    Quote Originally Posted by jclovesu View Post
    Tim
    I would also like to replace my front tire for riding in sand, have Bridgestone 130/80-18 66p, so if I put on a Maxxis M6006 what size would it be to be smaller?
    Join Oathkeepes.org
    Because Home Land Security Begins @ Home: BPAUX.org
    Guns only have two enemies: Rust and liberals
    jim
    jim is offline
    Indio, CA
    100
    Does any have any feedback on the Shinko 130/80-18 66p for $76.00
    the site says it was made for the tw200
    Join Oathkeepes.org
  1. Maxxis Ceros vs Stock tire
    By FootDoc in forum Performance and Customization
    Last Post: 08-14-2013, 10:22 AM
  2. wtb stock rear tire
    By mkriley in forum TW200 Classifieds
    Last Post: 06-17-2013, 02:26 PM
  3. Stock front and rear tire
    By Woodi23 in forum TW200 Classifieds
    Last Post: 04-27-2013, 10:19 AM
  4. wtb stock rear tire
    Last Post: 01-17-2013, 11:32 AM
  5. WTB Stock Rear Tire
    By wrhux in forum TW200 Classifieds
    Last Post: 05-20-2012, 01:59 AM
kenda big blocks in sand
maxxis 6006 replacement
