Zongshen Kick Starter Kits for the Yamaha TW200 - Page 12
Page 12 of 16 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 158
Like Tree346Likes
Thread: Zongshen Kick Starter Kits for the Yamaha TW200
  1. #111
    Junior Member ValJean9430's Avatar
    Apr 2013
    3
    Yep I'm going to want one of those too when we all find out this works. How do I sign up?
  2. #112
    Senior Member Gulfrider's Avatar
    May 2014
    Florida Panhandle
    587
    so whats the update on these kits, Brian got the test kit yet?
    2005 TW200
    2007 Sportster 1200
  3. #113
    Pleasanton, CA
    5,590
    Quote Originally Posted by Gulfrider View Post
    Nope, not yet.
    Brian
  5. #114
    Junior Member joshuaz2's Avatar
    May 2016
    1
    I would like one for my new to me 06
    Roy
    littletommy likes this.
  6. #115
    Spokane, Washington
    17,187
    Welcome to the forum Roy!!
    1st John 1:9
    John 3:16
    John 3:17
  7. #116
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    This is a long thread and the answer may have been posted (to much to read) but i'll throw this out there.
    The washer with the tab is a "Wear Plate" and the outside washer is a "thrust washer".
    You don't want rotational wear against a soft part, in this case what looks to be (hard to tell for sure from pic) a cast bushing/collar. The "washer" (wear plate) with the tab takes care of this and inhibits any rotation against the bushing, on that side anyway.
    The thrust washer does what it's name indicates, takes up thrust.
    If the Chinese part "collar/bushing" is a hardened machined part there is no real reason for the wear plate.
    A thrust washer should be used so that the snap ring is not come in direct contact with the soft aluminum machined shoulder of the case cover.
    That's how I see it anyway..
    On a side note, and I did see this posted already by a pretty smart guy, "this possibly opens up a lot of opportunities for us with other parts.."
    Hey Mike, can you (or anybody else ) help me out here?
    Could you please explain the function and purpose (i.e., the need) for the washer with the two ears and the flat washer that float on the kick axle between the circlip and the side cover? These are the two parts that the Zongshen kickstarter assembly apparently does not have.
    Take your time, we've got about a month before the Zong parts show up .
    Thanks!
    Brian
    Attachment 27683
  8. #117
    Pleasanton, CA
    5,590
    Thanks for the explanation Jeeper!
    When the Zongshen parts show up, I'll do a side by comparison of the parts and report back.
  9. #118
    Apr 2012
    Out West
    2,984
    Question TW-Brian or TWilight etc probably know but does the kick shaft rotate while the engine is running or just when kicking ?
    If just when kicking the bike over then wear is never going to be a factor on these parts
    I also ordered up the Zongshen parts and will give them a close comparision with the mic to the OEM stuff and report back
    "It's Like Warm Apple Pie"
  10. #119
    Mar 2011
    3,880
    Just when kicking. I don't think wear is an issue. Unless your talking about not using a washer between the snap ring and the case cover. I knew you were going to be all over this
    Quote Originally Posted by PlacerLode View Post
    TWilight and PlacerLode like this.
  11. #120
    Apr 2012
    Out West
    2,984
    Thats what I was thinking so in this case I'm happy using non OEM stuff
    I'm still going to use the OEM case gasket and a few other parts but we can use the ZS cluster and maybe the kick arm (I'll use the kick arm for XT kits for sure) it will save a lt of loot on the kits
  1. Kick start kits arrived at Bay Area Yamaha
    By old w/?? in forum General Discussion
    Last Post: 12-05-2014, 09:16 AM
  2. Bay Area Yamaha Kick Starter Kit Pics and Instructions
    Last Post: 12-20-2013, 08:31 AM
  3. tw200 kick starter kit
    By grounder in forum Technical Help
    Last Post: 11-15-2013, 03:28 PM
  4. tw200 kick starter kit
    By grounder in forum Technical Write-Ups
1992 tw200 kick start seal
can you buy yahama tw 200 with kick start
kick starter armature parts diagram
kickstart kit for tw200
tw200 kick start kit
xt225 kickstart kit
yamaha ttr 225 kick start kit
yamaha tw engine
yamaha tw200
yamaha tw200 kick start parts
yamaha zs200gy-2
