Mule Nuts? - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 28
Like Tree14Likes
Thread: Mule Nuts?
  1. #11
    Junior Member eldavo's Avatar
    16
    +1 that is a great solution.
    Even if the threads rust solid it won't matter. That happened to the wrecked seat I bought to make the hybrid XT350 front tank portion. I managed to work the rusted snapped seat bolt out somehow.
    Tweaker likes this.
    '05 TW200 + Emgo handguards, RK O-ring chain, Cycleracks rear rack, John (Mule's) seat bolts, hybrid TW/XT350 seat, Clarke XT350 natural tank, 2inch bar raisers, Jimbo's cafe shield, Utah Sport Cycle's Ricochet Engine Bash Plate, Full synthetic oil for cooler operating, Updated Yamaha pleated oil filter. Soon to add - Acerbis supermoto higher front fender Not sure I'll fit at all - Northern star hurricane oil cooler with Spal fan, John (Mule's) oil cooler filter cover, Wiseco high compression piston.
    Hidden Content The TW200 Wikipedia
  2. #12
    Senior Member catamount's Avatar
    Aug 2010
    Vermont, USA
    323
    Quote Originally Posted by Rich View Post
    I smell a missing link award for you cat
    Not for me! But maybe for either of the two guys who posted their solutions above!
    Check out my custom TW200 build Hidden Content .
    TTR225 SS header, FMF Turbine Core 2 pipe, EK o-ring chain, 15T front sprocket, 50T rear sprocket, 20W fork oil, Drag Specialities speedometer, Victory Vegas headlight, Acerbis universal supermoto front fender, Vintage Yamaha chrome gas cap, Integrated LED rear tail/turn/brake light, Yamaha Blaster shock, Pro Taper SE ATV High handlebar, Western Powersports off-road handguards, Pro Taper Pillow Top Lite grips, Over-sized foot pegs, Maxxis 6006 front tire, seat cover from eBay seller mac32756.
  3. #13
    Tennessee
    1,300
    This is great. The previous owner of my TW just put the bolts into the seat but not through the bracket. I don't really get any wiggle though when I'm on it. Hitch pin idea is great though.
  5. #14
    1993 TW200 in Meridian, Idaho
    1,533
    Here's my solution to the problem of having to have tools to take off the seat - Perhaps since they use wingnuts as a primary component, I'll call these "WingDings."
    You can see they use a metric bolt, a wingnut, a locknut, and a short nylon sleeve. I ground the nylon sleeve down from it's original length on a bench grinder. I think were I to re-make these I'd get a little longer bolt and make the sleeve a bit longer too to be sure the wingnut was well out of the way of the seat bracket.
    raimix007 likes this.
  6. #15
    Aug 2010
    Vermont, USA
    323
    Quote Originally Posted by JS5owner View Post
    Here is my solution - a hitch pin, aptly named: Mule hitch pin! [grin]
    Okay, so I confirmed tonight at the local hardware store that this pin is in the metric section:
    M6 x 40 (or longer if you like), 1.00 pitch.
    I ended up building two for myself at a grand total of $2. Thanks JS5owner!
  7. #16
    1,533
    Quote Originally Posted by catamount View Post
    I like this solution even better than mine, but am wondering how you get the hole in the pin? (Is this a bolt with the head cut off??) Bolts are typically pretty hard metal and drilling the hole seems not very easy.
  8. #17
    Tennessee
    1,300
    Quote Originally Posted by Truelight View Post
    The pin is made just like that with the hole in it. It's usually used to connect a hitch to a vehicle or any tow behind equipment. Very handy in all sorts of situations.
  9. #18
    Aug 2010
    Vermont, USA
    323
    Quote Originally Posted by assquatch20 View Post
    I wish! I doubt you'll find such a small pin (M6) as a hitch pin.
    The bolt is small so you'll have to drill it yourself. I cut the head off the bolt and then put it in a vise. Using something sharp and hard like a nail, I'll get an indentation going in the bolt. Then you just drill a straight hole through it.
  10. #19
    Nice. I'll be doing this mod this afternoon.
    I saw a Suzuki rider using hitch pins to secure his seat launch his seat off a cliff. If you ride in a lot of thick brush that could be an issue. Probably not more than a 1:1,000,000 chance of losing both pins at the same time, though.
  11. #20
    Senior Member JS5owner's Avatar
    Palm Springs / Desert Hot Springs
    308
    You are welcome catamount! What I like about this board is the collective knowledge that is shared. I've learned so much from all my fellow T-dubers! I do wish this new board kept the "stats" of the old board. I.e. how many posts, etc. etc. but I'm totally grateful for Chopper Charles for "herding the cats" here.
    2007 TW "Muley": Cyclerack rear, 55 tooth rear sprocket, Duro Power Grip & Shinko SR241, Clarke tank, Ricochet bash plate, Mule hitch pin quick seat removal, Trail Tech Vapor w/ Dashboard, hardwired Garmin 60csx & 205w, 12vdc adaptor, independent high beam off/on and signal beeper, modified seat.
    2000 Yamaha V-star 650 Custom - [sold]
    2009 Yamaha WR250R - "Willie Boy" the slimmer faster brother of my Muley.
    2009 Hidden Content . Wow, what fun on the highway!
  1. I found a 91, but I think the guy is nuts...
    By Tom Bettiker in forum General Discussion
    Last Post: 04-09-2013, 08:02 PM
  2. TW and competition for Mr. Bracket’s moto-mule
    By old white truck in forum TW200 Classifieds
    Last Post: 02-18-2013, 09:52 AM
  3. "Mule" Magnetic Drain Plug
    By Live2Ride in forum Performance and Customization
    Last Post: 05-04-2012, 07:41 PM
  4. TTW200... Yes, I am nuts. Yes, I am new to this forum.
    By morganlowe in forum Performance and Customization
    Last Post: 04-20-2012, 08:26 PM
  5. Mule Logging with the Cycle Rack
    By admiral in forum General Discussion
    Last Post: 10-19-2010, 10:43 AM
arlen ness grips victory vision discount
do mules have nuts
mule hitch pin
mule nuts
mule nuts & seat
mule nuts & seat tw200
mule seat tw200
mules nuts
nuts mule
tw200 forum mule nuts
tw200 mule nuts
tw200 quick releqse seat
