Front tire choices - Page 2
Page 2 of 36 FirstFirst 123412 ... LastLast
Results 11 to 20 of 360
Like Tree336Likes
Thread: Front tire choices
  1. #11
    Jul 2011
    1,123
    <removed double post>
    ITCB
  2. #12
    Jul 2011
    1,123
    <removed triple post, and will stop using my cellphone on this site >
    joarc likes this.
    ITCB
  3. #13
    Senior Member atleastbehandy's Avatar
    Apr 2011
    Toronto, Canada
    250
    Quote Originally Posted by operose View Post
    Just finished up 20 miles with a rear tire chain and "regular" k270 rear tire on front. Conditions were a mix of fresh packy snow on top of sugar snow on top of a crust w/ more sugar underneath, some packed (but not groomed) snowmobile trails, and pavement covered in a mix of snow+sand.
    Can't complain about the kenda. The only times it wanted to wash out were when I let the front go into iced over snowmobile ski ruts. Other than that it was rock solid and I won't hesitate to ride more in the winter. Do really want some screws to help with traction on ice though for sure, just based on the other day's experience in the yard.
    Sounds like you had 3x the fun!
    What size K270 are you running? How is it at high speeds (wobble/squirrelly)?
    2005 TW200, 2" PowerMadd bar riser, Tusk D-Flex Hand Guards, PowerMadd Hand Muffs, Kick-Start, Valco Cup Holder, Givi E45N Top Case, Inline fuel filter, Storage Tube with MSR bottle, 45 Tooth sprocket, Stebel Low Tone horn, #130 Main Jet / no needle shims / 1.5 turns out on idle, Jimbo Shield, DID O-Ring chain, Clarke XT250 4.1 Gal tank, Custom Cycleracks
  5. #14
    Frosty Hollow
    13,095
    I have a Shinko 244 in 5.10-18, cousin of the 270. Ditto what Operose just mention with for riding in the snow. A ton better than the stock. Off-road/logging roads, it's been super. I ride with lower tire pressure when riding on any type of road surface other than tar (10-12psi normally). I can't compare using a smaller size like xdac has, but I've not felt uncomfortable or had any problems steering or leaning on or off-road.
    I don't ride a ton on tar roads, but when I do, I've had no problems there either. Normally I ride around 55-60 mph on tar and it's been nice and smooth, no problems with steering, wobbles or other issues at any speed. Just the whine of a knobby tire on tar.
  6. #15
    Senior Member NumberThree's Avatar
    124
    I run the IRC 110r, since I'm a bit more road than dirt, but it seems to do well in both contexts.
  7. #16
    Apr 2011
    Toronto, Canada
    250
    Quote Originally Posted by NumberThree View Post
    Thanks, added above.
    What size did you choose? How does it compare to stock? Any issues?
  8. #17
    Apr 2011
    Toronto, Canada
    250
    Quote Originally Posted by n2o2diver View Post
    For the street oriented
    Bridgestone TW203 Trail Wing Dual Sport Front Tire
    Thanks, added.
    Do you run this tire? If so, how does it perform off-road? I have seen a few posts on how bad this tire is in the dirt. But much better than stock for wet pavement.
  9. #18
    124
    Quote Originally Posted by atleastbehandy View Post
    5.10... seems ok, definitely smoother than stock. I think it's probably heavier too, but to be honest, I haven't noticed a big difference in handling. Not as good in muddy, slick stuff, obviously...
  10. #19
    Jul 2011
    1,123
    I am running the rear-size tire up front. My TW doesn't go "high speed" really but the tire felt fine up to somewhere near as fast as the bike will go (68mph indicated maybe?). No experience with other tires to base this against though so someone else will have to chime in with a more knowledgeable reply, here.
    ITCB
  11. #20
    Jun 2011
    Dothan, AL
    1,715
    Thanks, added.
    No I haven't run one of these. A few of the guys with Hollow Mods have, maybe they can offer an opinion.
    2005 TW200 (SOLD)
    2013 DR650
  1. Shinko 244 Front Tire
    By Phantom99 in forum Performance and Customization
    Last Post: 07-31-2017, 12:30 PM
  2. 160 front tire
    By Mr. BigWheel in forum Performance and Customization
    Last Post: 04-28-2012, 02:50 AM
  3. Phat front Tire
    By Batman1USA in forum Performance and Customization
    Last Post: 03-28-2012, 11:20 AM
  4. What front tire to use for 50/50 on/off road use?
    By the-wild-man in forum Technical Help
    Last Post: 10-23-2010, 11:06 PM
  5. Fat Front Tire
    By Jerrcik in forum Performance and Customization
    Last Post: 08-17-2010, 07:31 AM
best tires for tw200
tire size
tires for tw200
tw 200 tires
tw 200 tyre price
tw200 front tire
tw200 front tire options
tw200 front tire size
tw200 tire size
tw200 tires
yamaha tw200 front tire
yamaha tw200 tires
