Front tire choices - Page 36
Page 36 of 36 FirstFirst ... 26343536
Results 351 to 358 of 358
Like Tree328Likes
Thread: Front tire choices
  1. #351
    Member Denn's Avatar
    Dec 2018
    Arizona
    80
    I put a Shinko 241 on mine tonight. I took one lap around the neighborhood and I didn't crash so I guess it is good so far
    I'm hoping to hit some back country later this week.
  2. #352
    Junior Member Krakrak's Avatar
    Apr 2019
    Laval, Quebec, Canada
    26
    The 241 looks interesting but what about the fact that it's not intended for extended highway use?
    What is "extended" ? An hour? 5 hours? 30 min???
    On shinko's Canadian site there is not a trace of this warning, only on the American site.
  3. #353
    Oct 2018
    Rural, South Carolina
    635
    Just order it from a Canadian site and you'll be all set.
    Purple, littletommy and Krakrak like this.
    2010 TW200 - The Goat
    Triumphs
    ATVs
  5. #354
    Senior Member BUMBLESPECIMOODA's Avatar
    Sep 2018
    OSHAWA, ONTARIO, FASCISTVILLE (I MEAN CANADA).
    129
    Did some good test'n of the Kenda Klassic K257D, 4.60-18-4-ply. Super grip, super stable in sand, rolls nice on cement (although I would not corner like motogp on it. Tall side-knob squirm). I highly recamend it, if you'all are doing a lot of offroading.
    Looks mean too.
    littletommy likes this.
  6. #355
    Senior Member bartruff's Avatar
    Oct 2018
    Wenatchee Wa.
    161
    I have had 4 TWs since 1987 and I ride about 90% on dirt and 10% on low speed low volume paved roads......I use whatever tires at whatever tire pressure (18 psi ?) they came from the factory with....have had zero problems....
  7. #356
    Junior Member Usadventureracing's Avatar
    May 2019
    Crystal Lake, IL
    Due to my location I will probably be riding more paved roads than dirt so are folks recommendations for tires? I have the stock tires on at the moment and so far they had been fine.
  8. #357
    Mar 2015
    Ynys Môn
    4,496
    The Bridgestone TW34 (stock rear) with a Shinko 241 up front will cover most things — although the 241 is fairly soft so it will wear more rapidly, but again, for 50 bucks it’s not that bad, and gives you excellent off road capability
    The “road going” tires for the TW, are the Bridgestone TW203 and TW204 combination. There’s a pair in our classifieds as today. Bit pricey (not the ones on sale here), but hard wearing very grippy tires on tarmac
    Not so hot off road as you can tell by the tread pattern, but with care, they will still get you most places
    I believe Shinko does a similar tire, slightly cheaper, check fleabay for model numbers
    As these “road tires” are best on tarmac when they keep their profile, you can up the tire pressures to 22psi to 25psi quite happily, which improves top speed and mpg — lower the psi to 18 or less for off road as you would expect. Running tarmac constantly at lower pressures will result in a “flat profile” on these, so carry a small pump with you
    Although the TW34 rear is excellent at both on road and off, try not to mix knobblies with smoother road tires — it’s not good for the handling at all
    But get rid of the stock front while you’re ahead — it’ll catch you out eventually ….
    https://www.tw200forum.com/forum/per...re-thread.html
    - Hidden Content
  9. #358
    Member Soulprogression108's Avatar
    Feb 2018
    94
    Well I just spent the evening reading almost this whole post and I’m no closer to picking a front. I’m in need soon and was close to ordering a k270 5.10 but now i think it’s too big. I need something 50/50 ideally. I ride a good amount on pavement and can’t afford to give up good handling there but desperately need better traction off-road than the stock. Mud, clay, sand, dirt, gravel, roots, rock reggae you name it it’s here. And often all in one trail. EVERYthing but snow and ice thankfully 😅
  1. Shinko 244 Front Tire
    By Phantom99 in forum Performance and Customization
    Last Post: 07-31-2017, 12:30 PM
  2. 160 front tire
    By Mr. BigWheel in forum Performance and Customization
    Last Post: 04-28-2012, 02:50 AM
  3. Phat front Tire
    By Batman1USA in forum Performance and Customization
    Last Post: 03-28-2012, 11:20 AM
  4. What front tire to use for 50/50 on/off road use?
    By the-wild-man in forum Technical Help
    Last Post: 10-23-2010, 11:06 PM
  5. Fat Front Tire
    By Jerrcik in forum Performance and Customization
    Last Post: 08-17-2010, 07:31 AM
best tires for tw200
tire size
tires for tw200
tw 200 tires
tw200 front tire
tw200 front tire options
tw200 front tire size
tw200 tire size
tw200 tires
twinduro
yamaha tw200 front tire
yamaha tw200 tires
