Adding a Kickstarter - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Like Tree9Likes
Thread: Adding a Kickstarter
  1. #21
    Senior Member flingwing1969's Avatar
    Apr 2012
    Shasta County - In the Shadow of Lassen Peak
    374
    <Continued>
    4. Now, a special tool, a vise. The spring is very stiff so don't bother trying to push down on the ball with the flat of a screwdriver (for example) - doesn't work, I've tried it. It doesn't take much force but you'll need to put the kick lever and boss between the jaws of the vise and turn the vise in slowly until the ball disappears and clicks into the hole in the lever.
    5. Now just replace the screw hand tight, then give her a couple of palm slaps onto the end of an impact driver and Bob's your uncle, you're done.
    My wife has "suggested" that maybe some of the ranch projects should precede the installation of my kick starter so I'll post the final later - I won't bother to post the install process as it's been done before - just the final results and how it clears all the stuff that the XT only boss didn't. Later . . .
  2. #22
    Apr 2012
    374
    In case you noticed, yes, that is the TW boss I'm removing and reinstalling. I got so excited to get the parts that I popped off the XT boss and put on the TW then - Doh - forgot to take pictures. I'm too lazy to pull the TW boss off, reinstall the XT boss, pull the XT boss off, then install the TW - you understand.
    greenbomb likes this.
  3. #23
    Junior Member Idaho's Avatar
    May 2015
    Orofino, ID
    3
    Post kickstarter installation instructions, easier to read
    I found the print-off of the instructions hard to read, so I typed them up. Thought i would share along with the diagram.
    Attached Files Attached Files
    06 TW 200
    06 Ducati 620
    Today will be a good day.
  1. adding a Rev counter and better Lights
    By dubstep in forum General Discussion
    Last Post: 02-07-2015, 01:53 PM
  2. Could have used a kickstarter today
    By howardgene63 in forum General Discussion
    Last Post: 08-03-2013, 01:51 PM
  3. Adding cone filter
    By risingpowers in forum Performance and Customization
    Last Post: 01-12-2012, 09:49 PM
  4. adding extra lights
    By dubstep in forum Technical Help
    Last Post: 11-09-2011, 08:39 AM
  5. Kickstarter questions
    By Larry in forum Technical Help
    Last Post: 06-15-2011, 09:15 PM
can i add a kick start to my yamaha riva
kickstart add-on to tw200
kickstart for tw200
tw 200 kickstarter
tw200 kick start
tw200 kick start kit
tw200 kick starter
tw200 kick starter kit
tw200 kickstart
tw200 kickstart kit
tw200 kickstarter
yamaha tw200 kickstarter kit
