Installing a Clarke XT225 tank - Page 3
Results 21 to 30 of 38
Like Tree26Likes
Thread: Installing a Clarke XT225 tank
  1. #21
    Senior Member Guitarman's Avatar
    Jan 2012
    Trois-Rivieres, Canada
    167
    Quote Originally Posted by shiftline View Post
    Excellent tutorial, the hockey pucks work perfectly.
    When you put the seat back on did it still hook under at the front or does it just float there now?
    Thank you shiftline!
    My seat hook under at the front with the bracket. Darnold87 told me he was able to hook it lower, just like with the stock tank.
  2. #22
    Jan 2012
    167
    Quote Originally Posted by peraevum View Post
    Anyone ridden their Clarke XT225 tank from full to reserve to empty yet? Just curious about the estimated miles you guys are getting out of each full tank. I'm at about 80 miles on my tank and it looks like there's still quite a bit of fuel in there. It will be interesting to compare how much more the Clarke XT225 tanks get vs. the Clarke TW200 tanks.
    I rode it to reserve once and there was 135 miles on the clock.
    Today I did a little bit more miles before fuelling without having to switch to reserve.
    My average mpg is about 60.
    I hope it helps
  3. #23
    Junior Member peraevum's Avatar
    Jan 2012
    Chicago, IL
    14
    Thanks, Guitarman. I'll look out for that. Interesting that n2o2diver in the main Clarke Tank Group Buy thread is seeing 150 miles before reserve on a Clarke TW200 tank. I know every person is going to have a different mpg pattern though. Just want to get a good estimate of how much of the fuel at the bottom of the tank is stuck because of the angle of the tank to the petcock.
    Quote Originally Posted by Guitarman View Post
    I hope it helps
  5. #24
    Senior Member bikerjosh's Avatar
    Walnut Creek, CA
    1,066
    Quick question about petcock clearance. Does this look correct? Seems to stick out quite a bit, and frame closeness will require a pretty tight bend to reach carb inlet. Heading to auto store for some fuel hose since my previous pre-carb filter won't fit. On a seperate note, I used Danwray's idea of running another hose off the petcock w/a clunk at the end to keep it in the deeper part of the tank.
    thanks for looking-josh
    Not all men are capable of greatness, but all possess toughness.
    2001 TW a mod or two maybeHidden Content
  6. #25
    Jan 2012
    167
    I'm sorry for the delay bikerjosh, I didn't receive the notification for your new post.
    It looks correct to me! mine is just like that. Yes the bend is a bit tight but I did not experience any issue in about 3500 miles of on and off road yet. ;-)
  7. #26
    Senior Member Dmd3058's Avatar
    Jul 2011
    Pittsburgh Pa
    144
    10. Cut your side covers so they fit and compliment your new installation (I used tin snip). Drill two small holes, one on each covers, where they meet the frame and zip tie them in place so they won't fly while cruising on the highway (thank you lzrdbrth for the suggestion, I just red your post this morning about your experience)
    11. Install your stock petcock. It will fit, but it's a tight fit.
    12. Put your seat back on and take care to slip the tab under your new bracket
    Voila! You can now enjoy your ride again without having to fuel four times a day ;-)
    If you want your installation to be perfect, you will need handlebar risers or your stock bar will hit the tank at full turn.
    I insist on risers because I first installed a Protaper ATV High bar and had the same problem, the base of the bars (where it bolt to the triple tree) would hit the tank. I was lucky I had some risers on another bike that I could use. Problem solved.
    I will try the setup as it is now and see if I like it. The bar sit pretty high and I'm a bit worried about the cables I had to reroute. They seem ok but I'll definitely keep a good eye on them in search of any premature wear. There is no binding as I call tell, but they are surely tighter than they were before.
    I'll keep you updated on that.
    is this a stock xt225 tank or a 4.1 g one from clarke. thanks
  8. #27
    Hailey, ID
    3,377
    That's a plastic Clarke tank.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  9. #28
    Junior Member Machine's Avatar
    Jul 2015
    25
    Hey look over in general discussion im designing a sub cell worth around 2.75 - 3 gallons fits under the seat works well with your stock1.5 or 1.2whatever it is factory saddle tank look for thread by machine sub Cell for tw 200 would like everybody on the forums input on on this concept because I'm working on it as we speak will have pictures in a few days
  10. #29
    Junior Member devilnutzUSMC's Avatar
    Oct 2012
    San Francisco, CA
    6
    Anyone by chance have photos of their clarke xt225 install? For some reason I'm getting a "Please update your account to enable 3rd party hosting" box where the above photos should be...Thanks!
  11. #30
    Mar 2017
    Yuba City, CA
    394
    Welcome to the forum!
    If you do an internet search for "photobucket fix," you can download an add-on for whatever browser you're using, which will allow you to view photobucket hosted pics.
    Semper-Fi!
  1. XT225 Tank
    By r80rt in forum Performance and Customization
    Last Post: 05-09-2016, 03:57 PM
  2. very nice 2007 xt225 fuel tank with shrouds
    By josh in forum TW200 Classifieds
    Last Post: 02-18-2013, 06:59 PM
  3. XT225 Tank for Brock
    Last Post: 01-13-2013, 11:11 AM
  4. FS: Clarke XT225 4.1 gal gas tank
    By d-nix in forum TW200 Classifieds
    Last Post: 12-09-2012, 09:38 PM
  5. Clarke Tank Fit
    By ldw72120 in forum Technical Help
    Last Post: 07-01-2012, 03:18 PM
clarke xt225 tank
modifying xt225 clarke tank
tw200 clarke xt225 tank
tw200 fuel tank
tw200 oversize tank
tw200 xt225 tank
xt225 fuel tank
xt225 gas tank
xt225 tank
xt225 tank on tw200
yamaha tw200 gas tank
yamaha xt225 gas tank
