Installing a Clarke XT225 tank - Page 4
Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
Like Tree26Likes
Thread: Installing a Clarke XT225 tank
  1. #31
    Frosty Hollow
    13,098
    Quote Originally Posted by devilnutzUSMC View Post
    Anyone by chance have photos of their clarke xt225 install? For some reason I'm getting a "Please update your account to enable 3rd party hosting" box where the above photos should be...Thanks!
    Here is a possible fix thread for you to view. When I did the fix it was easy and fast.
    https://tw200forum.com/forum/tw200-pi...ser-users.html
    turbodieseli4i6 likes this.
  2. #32
    Junior Member devilnutzUSMC's Avatar
    Oct 2012
    San Francisco, CA
    6
    Thanks admiral and cj7pilot!. Worked like a charm.
    littletommy and admiral like this.
  3. #33
    Member Downs's Avatar
    Dec 2017
    Greenville, Tx
    69
    Thanks for the link to the photobucket fix. That worked great. I'm in the middle of a XT225 clark install on my TW and without the pictures I was lost.
    littletommy and Fred like this.
    2004 VSTROM 650
    1978 GS1000
  5. #34
    Dec 2017
    Greenville, Tx
    69
    Got mine put on. Pretty much followed the original post but fabed up some wooden pucks instead of hockey pucks because those are almost impossible to find in my area. I cut them 3 inches long and rounded the ends with a grinder. Drilled the holes about one inch on center from the end. Worked great.
    I wound up only trimming the left had side panel to make access for the fuel valve.
    Sent from my SM-G892A using Tapatalk
    2004 VSTROM 650
    1978 GS1000
  6. #35
    Junior Member Rpmfly1's Avatar
    Jan 2018
    Des Moines, Iowa
    25
    Thanks for sharing! Ordered one for my ttr225 in blue!
  7. #36
    Junior Member Grundieg's Avatar
    Oct 2017
    4
    This is my custom fuel tank. 21 litres...
    TW-Brian likes this.
  8. #37
    18,857
    Invalid attachment Grundieg.
  9. #38
    Senior Member EatElk's Avatar
    Sep 2018
    Boise, Idaho
    298
    Guitarman- Thank you!!!!!!! Love not having to reinvent the wheel. Few notes: sawsall cuts hockey pucks with efficiency. I used a pipe insulating sleeve as padding under the tank. Used the padding supplied to pad under the seat at the bracket. I also used pipe insulation to cover the gaps with the side covers. I did all this in just a couple of hours. Thanks again for pointing me in the right direction! Next up- ROX 2" handle bar risers and a kick starter!
    TW-Brian, SpeedyTide and Jim Boggs like this.
  1. XT225 Tank
    By r80rt in forum Performance and Customization
    Last Post: 05-09-2016, 03:57 PM
  2. very nice 2007 xt225 fuel tank with shrouds
    By josh in forum TW200 Classifieds
    Last Post: 02-18-2013, 06:59 PM
  3. XT225 Tank for Brock
    Last Post: 01-13-2013, 11:11 AM
  4. FS: Clarke XT225 4.1 gal gas tank
    By d-nix in forum TW200 Classifieds
    Last Post: 12-09-2012, 09:38 PM
  5. Clarke Tank Fit
    By ldw72120 in forum Technical Help
    Last Post: 07-01-2012, 03:18 PM
clarke xt225 tank
modifying xt225 clarke tank
tw200 clarke xt225 tank
tw200 fuel tank
tw200 oversize tank
tw200 xt225 tank
xt225 fuel tank
xt225 gas tank
xt225 tank
xt225 tank on tw200
yamaha tw200 gas tank
yamaha xt225 gas tank
