The Dual Sprocket thread - Page 2
Page 2 of 18 FirstFirst 123412 ... LastLast
Results 11 to 20 of 176
Like Tree84Likes
Thread: The Dual Sprocket thread
  1. #11
    Senior Member Sly Fox's Avatar
    Oct 2010
    Wiltshire, UK
    203
    Wow!! This is really exciting!!! (Why didn't I think of it??)
    We're in 'Bat Country' now....
  2. #12
    Member eviee1973's Avatar
    1999 TW200 Dartmouth, Nova Scotia
    42
    Basically same idea as my 1964 Honda Trail 90 from the factory, except for the dual front sprockets.
  3. #13
    Senior Member darnold87's Avatar
    Salem, OR
    908
    Quote Originally Posted by eviee1973 View Post
    Exactly... those had much more variance between to the two rear sprockets right? A small one and a huge one? Which also required adding a sectrion of chain? That's what I've heard anyway.
    I may add a larger rear sprocket someday, but it's nice having the rear sprockets be similar enough in size to not require adding a section of chain. Simple-Simple.
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
  5. #14
    I've run wheel sprockets with a difference of 4 teeth without having to mess with chain length. Not much room in the adjustment slot for more than that.
  6. #15
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,514
    Qwerty, I will say, you are likely correct. There is however, ample room to elongate the slot. In my opinion, when a mod option is presented, the modder needs to be aware that 'he' may need to deal with a few "unstated issues." If memory serves, I did indeed move (increase) the slot forward. As well, I modified the chain adjusting cams to afford me more slack when loosening the chain. Gerry
    Take care my Friend.........
  7. #16
    Salem, OR
    908
    With the 14/47, 14/50 setup, I didn't have to modify anything... All just bolt on parts.
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
  8. #17
    Senior Member TWrider's Avatar
    1987 TW200 OHIO
    567
    Funny story about the Honda 90, I forget if I read it here or somewhere else. When Honda first released the 90, there was a dealer in California who would modify them with 70 tooth sprockets and grip tires, They did great in the foothills with these mods, the things would fly out the door. So when the Honda brass took notice of why this dealer was selling more Honda 90's than anyone else, they immediately dispatched some eggheads to figure out why. Their response was the dual range sub transmission.
    LOL, times have changed so much, do you think Honda would give it's customers the time of day in 2010? They'd probably respond by pulling the dealers license over liability issues....
  9. #18
    Desert, SoCal
    7,369
    I want to run a 55/70 combo on mine, but I'm a bit concerned about the unsplined area on the front shaft.
    I'm gunna look into one-piece industrial double sprockets for the front. Anyone already beaten that horse?
  10. #19
    Senior Member Henrici's Avatar
    Sep 2010
    Big Island, HI
    180
    Is there a downside to just adding a small section of chain to avoid having to loosen and adjust the rear tire every time you change which sprocket you drive?
  11. #20
    Paradise, Calif.
    3,514
    My ability to recall "exactly" has been somewhat compromised, likely a genetics thing as my Father would offten forget my name. In my opinion, should you be willing to pay a machinist, you should be able to get your 'secondary' primary sprocket indexed with as many coil pins (strong) as you want. I believe the stock shaft provides 6 'teeth'. Unless you are big guy, and plan to race, in my opinion, you should be able to make your 'sister' sprocket attachment "strong" enough.
    Nothing wrong with adding extra length of chain to get an even wider spread in your ratio options. There will be a few opinions on this to be sure. No matter if you boughht your bike new (me) or bought used. To me, the TW is a simple and inexpensive bike, parts like sprockets and chains are very affordable. Certainly, mis-matching components that have been subject to different degrees of wear would not represent the 'ideal', but in my opinion, nothing about the bike was made to represent the 'ideal'.
    Certainly, all of the above represent 'less' than optimum conditions (factory stock). I have mentioned before, my main concerns are (1) SAFETY and (2) convenience.
    I tried the wider spread (gearing) with the added section of chain. For me, this added enough time (not much) and energy to the ratio switch, as to suggest I would not be inclined to fuss with adding/subtracting chain sections to achieve my goals. You still need to loosen and re-tighten the axle to put in place the new section of chain and get it properly tensioned..
    In just dealing with the rear sprocket I am of the opinion that any 5 tooth spread is available. Here are some examples; should you be primarily a street commuter, but like trails, try a 45/50 rear combo. If you (like me) are into back country exploring, how about 50/55. Now in changing the front as well, offers an even greater spread.
    I am not selling anything, but am certainly pleased when someone gleens value from my ramblings. There are a few that continue to 'walk the planet' because they don't trust flying machines. Study well, and use whats available to your benefit. Sounds good to me, Gerry
  1. The Dog Thread
    By Point37 in forum Off-Topic
    Last Post: 10-12-2019, 02:17 PM
  2. Dual Rear Sprocket 45T & 50T
    By koonercat in forum Technical Help
    Last Post: 06-15-2012, 06:46 PM
  3. Thread Updates
    By Gerry in forum Off-Topic
    Last Post: 06-15-2012, 09:54 AM
  4. Replies: 0
  5. the big oil thread
    By YTWTX in forum Technical Help
    Last Post: 04-15-2012, 08:53 AM
dual sprocket
dual sprocket tw200
dual sprockets tw200
sprocket combo for mountain trails
tw200 axle nut torque
tw200 dual rear sprocket
tw200 dual sprocket
tw200 rear axle nut torque
tw200 rear axle torque
tw200 rear sprocket
tw200 sprocket
tw200 stock sprocket
