The Dual Sprocket thread
Page 1 of 18 12311 ... LastLast
Results 1 to 10 of 176
Like Tree84Likes
Thread: The Dual Sprocket thread
    Senior Member darnold87's Avatar
    Salem, OR
    908
    Red face
    Hey everyone~
    I know there is some great dual sprocket info on the old site but all the pics are gone and it makes it really challenging the visualize things.
    So, I propose we make this into the new Dual Sprocket thread where we can have all that info in one spot.
    There are different approaches and ideas for this subject.
    Here are a few: (I sourced the photos from various threads... hope that's ok)
    1. 1 front sprocket / 2 rear sprockets
    2. 2 front sprockets / 2 rear sprockets
    3. 1 front sprocket / 1 rear sprocket w/ outer bolt-on ring of teeth.
    I just upgraded to 14/47 and o-ring chain. I already miss the lower gearing. So I am planning to do some sort of dual sprocket setup...
    Please help build this thread into a great info source on this subject!
    GCRAD1 and Rpmfly1 like this.
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,514
    Nicely presented... In my opinion, there are a few considerations.
    1) How much work do you want to put into the mod?
    2) How much money do you want to put into this mod?
    3) How much time do you want to spend doing a ratio change......... Gerry
    Take care my Friend.........
    Paradise, Calif.
    3,514
    The dual front and rear sprockets are 'unique'. You can do it all yourself (I did on the 1st set) but likely, you would seek out a machinist and that would add to the cost.
    The advantage of the dual/dual sprocket mod is, you get a "very fast" 6 tooth spread in about as much time as it takes to lossen the rear axle nut. No chain length change is needed if you stay with the six tooth spread (one front, five rear). Of course, you need a wrench and would be inclined to get the rear wheel off the ground so it can be rotated. These issues would be the case with both approaches.
    The disadvantage of the dual/dual set-up is it's uniqueness. The second primary sprocket is not held in place by splines on the shaft, it is mated to the stock sprocket and held by two grade 12, 8mm allen bolts and 4 tempered 'coil pins' (very strong). Should you be an aspiring hot-dog Moto-Cross kind of rider, it is anyones guess if bolts and pins will hold. It has worked fine for me for a couple of years.
    For reasons that I can not explain, I generally move towards the bazaar. I have only switched ratios once when I was to do a longish pavement ride into the mountains. The change was fast, simply slacken the chain and roll it onto the adjacent sprocket set.
    My opinion; I like what I did alot. I took an idea and followed it thru to the point of success, I feel proud.
    As well, the overlay sprocket is tried and true........ Likely you won't need it often so fast is not really an issue. The overlay affords you a much wider range of ratios, all you need is to be willing to spend the extra time to add/remove an extra length of chain. Think it over before you decide..... Gerry
    {some more pictures} http://photobucket.com/mrgizmow
    boumboQC, GCRAD1 and DougDotyTW200 like this.
    Salem, OR
    908
    Thanks so much for the great info mrgizmow!
    That's exactly the type of information I was looking for.
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Salem, OR
    908
    OK, I chose option #2 for simplicity...
    So, I'm running:
    Front: 14-tooth JT sprocket
    Rear: 47-tooth & 50-tooth JT sprockets. (note: these sprockets have a machining to them, in that there's a recessed area where the mounting holes are)
    Custom fitted DID 428 o-ring chain. I'll have to count the links later...
    To switch between them, all you have to do is loosen the axle nut, loosen the adjusters, put the chain on the other sprocket, tighten the adjusters, and tighten the axle nut and reinstall cotter-pin. You should also confirm the rear brakes are adjusted properly. Total time to switch gears is easily under 5 minutes.
    The spacing worked out perfect. I'm surprised at how well the chain looks on either gear.
    For me, I'll usually run on the 50-tooth (bombing around town and running trails). But, when a longer distance ride is in store, a quick change-over will make cruising at 55-60 no problem.
    OK, here are some pics:
    This is a quick diagram to show the hardware used for the 6 bolts...
    Here are some different views of the dual rear sprockets: (note: blue color on 6 bolts is lock-tite)
    LuvNot and GCRAD1 like this.
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Paradise, Calif.
    3,514
    Looks good. Keep an eye on chain tension and in my opinion, you should never have a problem. If you want to keep it, with some slight modding, you can still use the chain guard. It's kind of neat to see someone adopt one of my 'unique' ideas. Gerry
    Salem, OR
    908
    Thanks mrgizmow!
    I knew I wanted to have 2 sprockets as soon as I saw your custom work...
    Then, after trying both 47 & 50 tooth rear sprockets seperately, it had to be done. I wanted both gear sets available with a quick change.
    Thanks again for your inspiration and ideas!
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
    Senior Member Henrici's Avatar
    Sep 2010
    Big Island, HI
    180
    So are there any long term negative effects of this set up? Or is the difference in the angle of the chain to minor to cause problems?
    Paradise, Calif.
    3,514
    I will add some insights as I may have more miles on mine than Darnold87. There seems to be give and takes with most mods. After a couple of thousand miles I did note some marking on the teeth of the slightly mis-aligned sprocket, but not enough to suggest that a sprocket replacement in 10,000 mile VS 15,000 would be an issue for "me". In my opinion, sprockets and medium quality chains are so reasonably priced as to make this concern a non-issue. For me, the important issue is flexibility. There are lots of posts on this forum regarding gearing. As a dual-sport bike, the stock setup seems to represent some middle ground. With the dual sprockets, you are able to move a 'bit' closer to prefect. If 'slight' mis-alignment is a major concern, you can spend a bit more time and money by adding a second primary sprocket. With the 4 sprockets (2 unique gear sets) you can get perfect alignment with each combo as each sprocket set will be spaced the same distance apart.
    Anytime you mod from stock, there is always (in my opinion) a chance for some nasty unforeseen issue to develop that could compromise your safety. Use care and think about what you are doing. Gerry
    Bagger and GCRAD1 like this.
    Salem, OR
    908
    mrgizmow has many more miles than I do on his setup and I agree with what he said...
    ~Davey
    '89 TW200
    '94 Suzuki Sidekick
  1. The Dog Thread
    By Point37 in forum Off-Topic
    Last Post: 10-12-2019, 02:17 PM
  2. Dual Rear Sprocket 45T & 50T
    By koonercat in forum Technical Help
    Last Post: 06-15-2012, 06:46 PM
  3. Thread Updates
    By Gerry in forum Off-Topic
    Last Post: 06-15-2012, 09:54 AM
  4. Replies: 0
  5. the big oil thread
    By YTWTX in forum Technical Help
    Last Post: 04-15-2012, 08:53 AM
dual sprocket
dual sprocket tw200
dual sprockets tw200
sprocket combo for mountain trails
tw200 axle nut torque
tw200 dual rear sprocket
tw200 dual sprocket
tw200 rear axle nut torque
tw200 rear axle torque
tw200 rear sprocket
tw200 sprocket
tw200 stock sprocket
