Anyone change their own rear tire?
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
    Senior Member Two Shoes's Avatar
    High Desert, California
    110
    If so what tools do you use? I can't even break the bead!
    Senior Member Boret's Avatar
    Aug 2010
    Northern VA
    404
    I use this tool:
    But that rear tire is pretty tough!
    Here is a great tire changing guide:
    LINK
    Desert, SoCal
    7,369
    Fun, ain't it?
    I've had a fair amount of luck using a giant C-clamp. If I can't actually break the bead with it I can at least cause a gap large enough to get a tire tool into and eventually manhandle it enough to get some daylight.
    After that there's the jack trick, the "run over it with the truck" trick, the Gizmow wedge trick....
    If rust under the bead is the culprit once you get it off, clean it up and sand the inside of the bead surface with some 400 grit then put some dielectric or silicone grease on it. Anti-sieze is messy, but it works and as far as I know it won't harm rubber. I put my Bighorn on with it in hopes I'll have some chance of getting it off the rim some day.
    Tried and true stuff like talcum powder, tire lube and dish soap tend to vaporize over time and that's desirable on most rims where using grease can become a safety issue, but as you can see a TW tire isn't in grave danger of slipping on the rim even if ridden flat.
    Senior Member brownie2's Avatar
    Sep 2010
    108
    Yep! Just used two 10" tire levers and some good balance. I stood on the tire lever and other side of the tire.
    Senior Member abyssdncr's Avatar
    Sep 2010
    Wichita, KS
    164
    Sure did, but I happen to have a 20 ton hydraulic press for building AKs that comes in right handy at tire change time. Notwithstanding this, I had a bear of a time getting the rear tire to break the bead as well as the press point kept slipping away from the rim. Ended up using a 6" piece of bar stock under the ram head to spread the load laterally and she finally gave up the ghost.
    2006 TW200, LED tail & turn signals, Clarke XT350 tank, hybrid YZ80 forks, CycleRacks rear rack, Ricochet bash plate, TTR225 header, eBay pegs, MSR high ATV bars, Tusk bar risers, Tusk handguards & deflectors, Tusk KX250 stainless brake line, XT225 speedo cable, 14/47 sprockets, Mule-pin seat latches, 130 main, 0.035" shimmed needle, TW34/M6006 meats.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,396
    Quote Originally Posted by Two Shoes View Post
    I use this bead breaker from Harbor Freight:
    http://www.harborfreight.com/bead-breaker-92961.html
    It's designed for car and truck tires, but has worked for me on motorcycle tires.
    jb
    Senior Member 805gregg's Avatar
    Oct 2010
    572
    I live near a motorcycle dealer in Ventura, CalCoast Motosports, they will match internet prices and if I take them the wheel they will mount it for free. You don't do your car tires why do the bike?
    1996 TW200 Edmonton, AB
    590
    Used the jack on my truck between the wheel and the bumper. That will break anything.
    Aug 2010
    Northern VA
    404
    All you really need is leverage.
    If you don't have the tools or a jack/truck combo like PJungnitsch suggested you can create your own with a couple of 2x4s.
    110
    Quote Originally Posted by 805gregg View Post
    I don't live near your dealer, I live near mine. They don't price match but they do charge an arm and a leg to mount/change, tires/tubes. I have had two flats and got the shaft each time paying local shops to swap the tube. Why waste 25 bucks every time you need or want to change a tire or tube? I change the tires on my bicycles myself why not do the TWs? I also mash my own cars and change my own oil.
  1. How to change your tire video
    By n2o2diver in forum Technical Help
    Last Post: 06-23-2015, 10:49 AM
  2. wtb stock rear tire
    By mkriley in forum TW200 Classifieds
    Last Post: 06-17-2013, 01:26 PM
  3. rear tire
    By 671tdub in forum Performance and Customization
    Last Post: 03-05-2013, 05:43 AM
  4. new rear tire
    By duckmutts in forum General Discussion
    Last Post: 02-28-2012, 02:02 PM
  5. Rear sprocket change out
    By k9scooter in forum Technical Help
    Last Post: 10-06-2011, 06:05 PM
anybody put a 18 rear wheel on a tw200
changing my yamaha tw200 14 inch rear tire to a 18 inch rear tier
changing the rear tire on a yamaha 200 tw
rear tire tw200
tw200 rear tire
tw200 rear tube
tw200 rear-tire
tw200 remove motorcycle wheel
tw200 seat bead
yamaha tw 200 tire change rear
yamaha tw200 change wheels
yamaha tw200 rear tire removal
