TTR 230 CC's and TTR 225 CC's Direrence
Results 1 to 10 of 10
    Poway CA.
    2,100
    Is there anyone who could tell me where the TTR230 gets the extra 5cc's over the TTR225. I have a complete TTR225 motor and (excuding carb) a almost complete TW200 motor and want to make a 6 speed, TW230 by combining both motors.
    Ronnydog
    Desert, SoCal
    7,369
    Marketing.
    Both are 70 x 58, near as I can tell.
    Senior Member abyssdncr's Avatar
    Sep 2010
    Wichita, KS
    164
    Double tap...
    2006 TW200, LED tail & turn signals, Clarke XT350 tank, hybrid YZ80 forks, CycleRacks rear rack, Ricochet bash plate, TTR225 header, eBay pegs, MSR high ATV bars, Tusk bar risers, Tusk handguards & deflectors, Tusk KX250 stainless brake line, XT225 speedo cable, 14/47 sprockets, Mule-pin seat latches, 130 main, 0.035" shimmed needle, TW34/M6006 meats.
    Sep 2010
    Wichita, KS
    164
    Marketing.
    Indeed, both are actually 223 cc:
    http://www.bikez.com/motorcycles/yam...-r230_2009.php
    http://www.bikez.com/motorcycles/yam...r_225_2005.php
    Bore it 1mm over and you get 229.63 cc...
    Desert, SoCal
    7,369
    Quote Originally Posted by abyssdncr View Post
    Which Yamaha did and they called it a 250. Go figger. It came in the Timberwolf/Beartracker.
    Reminds me of the movie "Spinal Tap"..... ""Mine goes to 11."
    Hadda be there. Old guy thing by now.
    Poway CA.
    2,100
    I talked to a factory rep and he said the 5cc is in the higher comp in the 230?
    Ronnydog
    Desert, SoCal
    7,369
    Quote Originally Posted by ronnydog View Post
    Ronnydog
    Higher compression would usually mean either LESS chamber volume, thinner gaskets, a domed piston, or a bore increase without changing the chamber volume. Doesn't make a lot of sense that they would increase it, but it would be interesting to know if there is a difference in the heads other than the spigots, since the valves seem to be the same. Practically hugging one another,no?
    All I gots is TW heads. I don't know. Normally combustion chamber volume isn't added to the published displacement of a motor, but maybe Yamaha is in fact doing the "Spinal Tap" thing.
    For those of you who aren't old enough to get the reference:
    http://www.youtube.com/watch?v=hN5SCRvhMtk
    Spinal Tap was a spoof film about a fictitious rock and roll band. Some of us old farts actually found this entertaining at the time. Go figger.
    Devon, England.
    614
    Ronnydog
    Your factory rep. has some funny ideas. My TTR230 cylinder has 223cc cast into the barrel and the Yamaha web site lists the TTr230 as 223cc.
    http://www.yamaha-motor.com/sport/pr...4/0/specs.aspx
    Poway CA.
    2,100
    Quote Originally Posted by uktw125 View Post
    So what is the dif in your 230 and the 225 in cc's?
    Devon, England.
    614
    There is no difference, as said before it's a marketing thing.
    TTR225 and TTR230 are both 223cc and both 9.5-1 comp. ratio. I think they may have different carbs, if this is a big enough change for Yamaha to consider it a new model I don't know.
beeg ttr
difference between ttr 225 and ttr230
ttr 225 vs ttr 230
ttr 230 vs ttr 225
ttr225 hybrid
ttr225 rear rack
ttr225 vs ttr 230
ttr225 vs ttr230
ttr230 same as ttr225
ttr230 vs ttr225
will a ttr 225 head fit a ttr 230
yamaha tw230
