TW200 Valve Adjust Instruction Tutorial wanted
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By cptrout
Thread: TW200 Valve Adjust Instruction Tutorial wanted
    Senior Member cptrout's Avatar
    S. Torrance (So. Cal.)
    353
    I know there's a pinned thread posted by Wes, and I appreciate his time and effort, for adjusting XT225 valves and that it's suppose to be similar to the TW but for some of us that's not good enough for a variety of reasons.
    If one or more of you incredibly knowledgeable guys would put together a concise tutorial on adjusting the valves on the TW200 myself and I'm sure others would be greatful beyond words.
    I still thank DXNomad everytime I change my oil.
    grewen likes this.
    Ephrata, WA
    1,125
    The only difference between the pinned tutorial on the XT and doing the valves on the TW is that you do not have tank shrouds and the clearances are different. The rest is the same.
    1990 TW200
    Senior Member sinophilia's Avatar
    Aug 2010
    Verona, Italy
    522
    This page is very detailed: http://yamaha.tw.free.fr/jeu_soupapes_tw.htm
    It's in French but you can translate it and it's full of images. It's about the TW125 but clearances are the same.
    Red Max - 1996 TW200 - 14/45, 320mm toothed brake disc, X-Racing titanium exhaust, Ricochet skid plate, Mule hitch pins, large pegs, VeeRubber VRM274&275 tires
    Ephrata, WA
    1,125
    Quote Originally Posted by sinophilia View Post
    That is a good site. Good pictures.
    1990 TW200
    Member BuddyMc's Avatar
    Huntsville, AL
    99
    Quote Originally Posted by Rainman View Post
    Adding a bit of information. The square top of the valve adjustment screw exactly matches a S2 square drive screw. Most square drive deck screws use a S2 drive bit. Buy / scrounge / find a square drive deck screw, run it into a round dowel or end of a broom stick, and you have the perfect valve adjustment screw holder.
    Huntsville, Alabama - Have TW, Will Ride! All White 09 TW, D2Moto Pegs, Bridgestone 302 front tire, 2" higher bars, 3/4" fork preload spacer, 5wt Honda fork oil, 135mm fork oil level, exhaust tip mod, 2.5 turns out fuel mixture, 0.060 in needle shims, 130 main jet, 14/47 sprockets, 20w-50 Valvoline MC full synthetic oil, ImmixRacing rear rack, Bilt Bag on Rack, 1" front fender spacers, Battery Tender connections on new battery (installed 12/11), Coleman ATV seat cushion, 2 Agri Supply tool tubes, 30oz MSR Fuel Bottle, auxiliary 6 LED tail light, Sylvania Silverstar Ultra H4 headlight bulb, 2357 turn signals, and Superbright's 1157 LED Motorcycle Tail Light Bulb with 19 red & 6 white LEDs. Shortened rear turn signals. Bypassed kickstand switch.
    Plus a "new to me" 1995 Yamaha Virago XV 750G for Pavement Purposes!!
    Member -Jake-'s Avatar
    Feb 2012
    81
    Member hooker's Avatar
    May 2012
    Wet side of the mountains, Washington State
    30
    Howdy All,
    Looking at the video it seems like a pretty simple operation to set the valves on the "older" TW's this would be true on my 1988 as it has the old style carb on it as does the bike in the video. However taking a look at the 2010 TW it has a new style carb on it that has the throttle cables routed just behind the intake valve cover, it looks like it might be a bit of a pain in the arse to get tools, feeler gages and fingers into the area needed to adjust this valve. So the question to those who have done this work on the bikes with the newer style carb, how much of a pain is it or I am seeing a problem where one doesn't really exist? Thanks for any guidance you can offer.
    ALL brand motorcycle lover and rider, long distance cross country rider, logging road and two track rider, year round sidecar rider. I have been told since young to grow up and act my age, I ain't doin it, I am too busy living my life even if it kills me. Visit my photo web site, ( Hidden Content )
    Senior Member rm_hm's Avatar
    1,619
    I take my Clarke fuel tank off, loosen the two carb clamps, remove the fuel line and twist the carb a little so it's out of my way.
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,513
    Hey Jake, NICE JOB!! Thanks so much for the extra effort. This is what makes this such a Great Forum. Can I post a link to your tutorial on the TW200 Wikipedia site? Gerry
    Take care my Friend.........
    Feb 2012
    81
    Quote Originally Posted by mrgizmow View Post
    go for it! add a disclaimer for me though lol
  1. Printed Manual, Supplement, Valve Tutorial and Carb Pics
    By n2o2diver in forum Technical Help
    Last Post: 01-30-2014, 08:04 PM
  2. Easiest way to get this 1994 TW200 going (bent valve)
    By JTpowersports in forum Technical Help
    Last Post: 06-03-2013, 01:10 PM
  3. wanted used tw200 04 to 07
    By trbixler in forum TW200 Classifieds
    Last Post: 03-08-2012, 01:31 PM
  4. tw200 wanted
    By phazer in forum TW200 Classifieds
    Last Post: 09-01-2011, 04:17 PM
  5. valve adjusters: intake valve died, who fights next?
    By jontow in forum Technical Help
    Last Post: 07-14-2011, 10:24 PM
at what valve clearence is yamaha tw200
immix xt225 cycleracks
put valves in tw200
tutorial on how to modify tw 125 into a tw 200
tw200 forum valve tutorial
tw200 valve adjustment
