Clutch slipping at high revs?
Results 1 to 10 of 17
Like Tree3Likes
Thread: Clutch slipping at high revs?
    Senior Member jgaff's Avatar
    Massachusetts
    124
    Hi -
    I am wondering if my clutch is slipping at high revs.
    1) 2010 TW200, stock, ~ 9300 miles
    2) New stock carb 100 or so miles ago, not shimmed or rejetted
    3) Slip seems to happen only in 5th gear above 40-45 mph
    4) Doesn't happen at high revs in other gears
    5) If revs are gently, slowly brought up in 5th it doesn't slip
    Could it be the carb? Fuel flow at higher speed/revs? If so, why not in all gears?
    THX
    JG
    Spokane, Washington
    17,280
    It does sound like the clutch. If you have a little free play and the cable isn't too tight, check to see where the arrow lines up with the line ( raised mark) on the case. Check also the return spring. If the mark doesn't line up with the arrow, it may be out of adjustment, you have to pull the right side case cover and adjust the clutch. Check then to see how worn they are, replace as needed. The bike weight and wind resistance and speed in 5th make sense too. With that mileage, it could need adjusted or if you have been hard on it, replaced. Keep us posted.
    1st John 1:9
    John 3:16
    John 3:17
    Massachusetts
    124
    THX! Haven't had time to check things out yet. I'll try to post back tomorrow with results or comments.
    littletommy likes this.
    Senior Member Leben's Avatar
    Feb 2013
    Iowa
    264
    I agree with littletommy that it is probably the clutch. Mine started doing the exact same thing at 10,000 miles and it went away after replacing clutch parts.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    igaffs' #4 and #5 make me wonder why it is not happening in any other gear as well ? ( I'm not a wrench by the way).
    Any headway igaff ?.
    Spokane, Washington
    17,280
    It's the wind resistance at higher speeds putting more of a load on the clutch, and only because he is babying it in 5th that it doesn't. It speaks clutch all the way if his other adjustments are in order.
    Most likely, he can fix it for now by adjusting the clutch itself and lining up again the line on the case with the arrow on the lever and adjusting the cable. He caught the problem early on, so may not have to replace yet. Hopefully. Still gotta take the right side case cover off though.
    1st John 1:9
    John 3:16
    John 3:17
    Massachusetts
    124
    Sorry, no chance to look over the weekend. Once I get in there, I will post back.
    Spokane, Washington
    17,280
    Thanks for keeping us updated.
    1st John 1:9
    John 3:16
    John 3:17
    May 2013
    Groton, NY
    2,663
    My '96 clutch slips a little also. I just ordered some hi-performance clutch springs. I'll let you know how they work. Synthetic oil not meant for motorcycles will affect it also.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Senior Member greenbomb's Avatar
    Apr 2014
    cherokee village Arkansas
    229
    Heavy duty clutch springs , just bit heavier but do the trick. Vesrah about $10 bucks
    docjekyll2002 likes this.
    Look at the bottom of this page under SIMILAR THREADS
    Norm in Arkansas
    2006 TW , Kick Starter , Shinko 241 front 4;00/18 ,Vesrah HD clutch springs. Carb jet Kit, Amsoil 10-40 , ALLSBALLS steering head bearings, Jimbo shield. Zeta drop -down bend handguards
    Ricochet skidplate from IMMIX RACING , BIKEMASTER Supersport mirrors XT350 fuel tank , member big foot pegs
    Honda XR 600 , KTM 300 , BMW 1100 gs , 327 Cushman Truckster , KTM 625 SXC . Ural with sidecar
  1. Clutch slipping
    By Zack in forum Technical Help
    Last Post: 04-24-2014, 12:22 PM
  2. Slipping clutch...????
    By rastaman in forum Technical Help
    Last Post: 07-29-2013, 11:09 AM
  3. Another Slipping Clutch
    By FnMag in forum Technical Help
    Last Post: 06-07-2012, 09:21 AM
  4. clutch slipping
    By dubstep in forum General Discussion
    Last Post: 02-03-2012, 11:57 PM
  5. Clutch slipping!
    By AttitudeXX in forum Technical Help
    Last Post: 10-18-2011, 08:10 PM
clutch slips higher gears on yamaha roadstar 1600
Tags for this Thread
