Anyone have a youtube on how to tighten tw chain?
Results 1 to 9 of 9
    Senior Member fandango's Avatar
    Dec 2013
    long island
    309
    Wink Anyone have a youtube on how to tighten tw chain?
    Would be helpful. . Thanks
    Dec 2013
    long island
    309
    Thanks I did this on my older tw with my friend. I need to adjust my brand new 2014 it only has 125 miles on it the dealer never a dusted it right.. shouldn't take longer then 10 min's to do?
    Member Crashking's Avatar
    Feb 2014
    63
    My owners manual actually has a different procedure for my 2014, when I get home I'll post it here
    Senior Member Holdnon72's Avatar
    Jan 2014
    New Jersey
    592
    Great info! Thats how I do mine Croatoan...
    I have an area rug in my garage. I put one of those large plastic furniture sliders under the rear tire when I adust mine. This helps the tire move into place on the snails. Tighten axle nut to 65 ft. Lbs
    Dont forget to adjust the free play for rear brake after adjustment is completed
    2013 TW200 Ims super stock pegs,zeta pro bend xc hand-guards,manrack,zeta muffs,Gerbing ultra light heated gloves
    Feb 2014
    63
    Quote Originally Posted by Croatoan View Post
    Ok here's a better one from a newer manual.
    Attachment 5751
    Attachment 5752
    You can download that manual and others here: https://tw200forum.com/forum/technica...r-manuals.html
    Mine is still different
    Senior Member indika666's Avatar
    Dec 2013
    Colombo, Sri Lanka
    109
    I have no video..! But i have experimented for a while now..!
    The center point to measure slack will be the middle of black chain guard plastic as shown in the manual..!
    As per my understanding of the chain tension, chain will be 1/2 inch away from the swing arm at its highest possible point when properly adjusted..! (measured at the centre point)
    When the chain comes stretched and comes 1/4 inch close to swing arm(nearly touching the swing arm) I re-adjust..!
    2006 TW200E (JDM) -> 100% stock, Shinko SR428 front, Bridgestone TW204 rear, 14/45 stock gearing
    Dec 2013
    long island
    309
    Quote Originally Posted by indika666 View Post
    Thanks how long does it take to adjust it?
    Spokane, Washington
    17,282
    10 minutes.
    1st John 1:9
    John 3:16
    John 3:17
    Dec 2013
    Colombo, Sri Lanka
    109
    Quote Originally Posted by fandango View Post
    yeah 10 mins maximum..!
    you just have to loosen the rear brake arm nut, loosen the axle nut, adjust as needed and re-tighten the nuts..!
    Make sure to re-adjust the rear brake light indicator if needed..! And double-check axle is properly aligned with the same snail marks on the both sides..!
    All those are very well explained in the manual..!
  1. TW200 flat tracking on youtube.
    By tumbleweed in forum Trails, Off-road, and Adventure Riding
    Last Post: 01-10-2014, 05:33 PM
  2. Found this on youtube...
    By tcepilot in forum Off-Topic
    Last Post: 11-03-2013, 06:04 AM
  3. Good youtube on setting valve and exhaust lash
    By OSOK in forum Technical Help
    Last Post: 09-05-2013, 05:35 PM
  4. Youtube video of TW & tail of the dragon
    By birdmove in forum General Discussion
    Last Post: 05-17-2011, 11:05 AM
  5. YouTube
    By Gerry in forum Off-Topic
    Last Post: 09-11-2010, 10:54 PM
2013 tw200 tighten the chain
how loosen rear axle
