Need help with early forks!
Results 1 to 7 of 7
    Senior Member tcepilot's Avatar
    May 2013
    Dayton Ohio
    765
    I need to know if 89 tw forks require you to remove the damper rod from the top with an extension or if it is bolted into the bottom. I know the early forks are different. Just not how... Busted fork seals in case you were wondering. Also what size hex will i need if you go in from the top? Thanks
    Sent from Android for Nook Tablet using Taptalk
    -tcepilot Hidden Content
    --- Psalm 23 Verses 4-5 ----
    Even though I walk through the valley of the shadow of death, I fear no evil,
    for You are with me; Your rod and Your staff, they comfort me.
    You prepare a table before me in the presence of my enemies; You have anointed
    my head with oil; My cup overflows. (New American Standard Bible)
    1,110
    I'd assume your '89 is the same as my '95. They come apart from the top. I made a tool by threading some 1/2 nuts on a piece of threaded rod then welding them in place. It's supposed to be 19mm (.748") but 1/2" nuts are .740" flat to flat and they worked fine. Length of mine is 17". Here's a pic. Click to make big.
    May 2013
    Dayton Ohio
    765
    I'm not sure I can do that. Are there other options? My friend has hex tools for it but he used 14mm on his ttr125.
    Senior Member Joemama's Avatar
    Apr 2012
    Lake County, Ca.
    1,241
    You don't have to weld the nuts to the rod. You can use 2 nuts on each end tighten to each other.
    1,110
    Did you read the tutorial by B-dub? He used a 12mm coupling nut (longer than a std nut) stuck into a 19mm socket on the end of a couple of extensions. Its about 1/4 down on the page of the tutorial. Again....a 1/2" coupling nut will work too.
    6,976
    Lots of ways to skin a cat...........................
    I think this is a 3/4" bolt, nut, and washer -- could be 19mm. I used a deep 3/4' socket and long extension and a piece of duct tape. Worked well and was cheap.
    May 2013
    Dayton Ohio
    765
    I saw somebody used a 19mm socket, and a 12mm coupling nut. So I will try that this weekend.
  1. HID lighting upgrade for early TW
    By philosobrad in forum Performance and Customization
    Last Post: 12-09-2013, 07:52 PM
  2. Replies: 5
    Last Post: 05-03-2012, 11:23 AM
  3. Trying to find early bikes
    By reillyyz125 in forum General Discussion
    Last Post: 04-09-2012, 01:19 PM
  4. Wanted: Early TW frame
    By vn_grnt in forum TW200 Classifieds
    Last Post: 03-22-2012, 09:45 AM
  5. Santa came early for me
    By xdac in forum General Discussion
    Last Post: 11-30-2011, 02:53 PM
fork tool
