Found the source of my hideous vibration.
Results 1 to 3 of 3
    Senior Member Indiana's Avatar
    Oct 2013
    Indiana, 40 miles south of Indy
    470
    Since I got my TW it has made a hideous sound at certain engine speed-load combinations. I found it this week!
    The headlight mounting bracket was not assembled properly. Now that I slipped the slot over the tab, the noise is gone. It also explains why I had to turn my headlight adjuster almost all the way to the limit.
    This picture is taken from under the headlight, with the headlight shroud removed.
    Senior Member 50short's Avatar
    Aug 2013
    Excelsior, MN
    287
    Well done!
    God willin' and the creek don't rise.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Way to hangin there !. Several folk have reported strange noise or something and at times find crazy little things as a result.....instead of it being something major .
  1. Replies: 9
    Last Post: 05-22-2014, 05:15 AM
  2. Power source
    By Abonnette86 in forum General Discussion
    Last Post: 01-29-2013, 10:23 AM
  3. bad vibration
    By nixdsg in forum Technical Help
    Last Post: 09-12-2011, 07:42 PM
  4. Source for 60+ tooth sprockets
    By lizrdbrth in forum Performance and Customization
    Last Post: 12-24-2010, 03:39 AM
  5. Handlebar Vibration
    By OakCliffThumper in forum General Discussion
    Last Post: 08-27-2010, 12:48 PM
