Even more carb questions
Results 1 to 6 of 6
Like Tree4Likes
  • 1 Post By Berryrider
  • 1 Post By ssgtrillium
  • 1 Post By GaryL
Thread: Even more carb questions
    Junior Member Berryrider's Avatar
    Apr 2014
    Central Ohio
    14
    I recently pulled my carb off, cleaned it some (it was pretty clean actually) reset the float height and put it back on the bike. I suspected that the starting problems I was having were mostly due to the incredible hoard of seeds (a couple of cups easily) that mice had carried into the snorkle so I was thinking that the air issues alone might have been causing my starting problems. The rubber intake boot (airbox side) was so shrunken and hard that it is barely on the carb. I'm afraid that even with moderate riding, that dust and crap will find its way into the carb, and that the carb will eventually be getting too much air - the bike starts easily, warms up pretty quickly and runs well right now. I ordered a new rubber boot that I want to install to forestall any future problems. My first question is - can you get the old boot off and the new one on without removing the carb? - there is not a lot of room in there with the carb on. Second question - if I have to remove the carb again should I replace the jets, float valve - etc. as a matter of course as one forum member suggested? I have had the bike for 1 year - the PO seemed to have done pretty good maintenance - and the bike is not giving me any carbeurator problems at this point. Some people love to tinker with their machines - I have so many (1 tractor, 2 riding mowers, an ATV, 3 push mowers, chainsaw, leaf blower, string trimmer, wood splitter, garden tiller, wood chipper, and 3 boat motors) and so much to do that I only want to do what is neccessary on the TW. Opinions?
    Fred likes this.
    Member manotickmike's Avatar
    Apr 2013
    Ontario, Canada
    93
    If it ain't broke...
    These things will run with all sorts of issues that'd strand you on a lesser bike. I DO like to be TOTALLY familiar with the carbs on all our bikes. I carry bits with me, and tools to dissemble them. Also a magnetic parts dish, and clean white cloth for a trailside work station.
    Happily, the carb will be easier to get in and out with the new boot.
    Apr 2014
    Central Ohio
    14
    My answer
    I figured out my own answers - for anyone who might care. No - I see no way of removing the air intake boot without removing the carb. To remove the old boot, sit on the left hand side of the bike, grab the old boot with your left. Using a flat bladed screw driver in your right hand - wedge the screwdriver between the old boot and the air intake box. pry and twist until you get an opening. Since you have a new boot don't worry about damaging the old one, even though the old brittle rubber is plenty tough and will stand a lot of gouging without damage. When you finally get some daylight via the screw driver, continue to work to widen the gap, twisting with your left hand to increase your advantage. At some point you will have gained the upper hand and it will pop out. Put a light coating of lithium grease on the new boot, air box side. With your left hand put the boot into position, angle the boot so the bottom of the groove of the boot just fits into the airbox frame. Use your flat bladed screwdriver and try to get an 1/8 or 1/4 quarter inch a time of the new boot stuffed into the box. Do this until you have about 1/3 of the boot in - rotate the boot clockwise with your left hand and work in the next little bit 1/4 inch at a time. Keep working the boot in a little bit at a time and rotating it with your left, eventually the whole thing pops in.
    Other than using a dremel tool to carve a slot in my boogered float chamber drain screw, I did not mess with anything else on the carb. I will order a new drain screw which I can replace with the carb in place.
    Fred likes this.
    Senior Member ssgtrillium's Avatar
    May 2014
    Wellington County Ontario
    614
    I just changed the same boot on mine and funny enough my drain screw is getting the dremel treatment tonight too.
    Fred likes this.
    18,710
    Great instructions, thanks Berryrider.
    Amazing how airboxes attract mouse stashes, many of us can share a similar story.
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,038
    I just replaced the air box to carb boots on both of my TWs. Remove the carb and warm the old boot with a hair blower on high or a heat gun on low. Wear grippy gloves and they come out pretty easy. Put the new one in a bowl of hot water for a few minutes before stuffing it in.
    Fred likes this.
    1987 Yamaha BW350 Big Wheel
  1. Building a competent T-Dub - questions. Lots of questions.
    By kawazacky in forum Performance and Customization
    Last Post: 04-05-2014, 10:39 AM
  2. Lazy Man's Carb Cleaning Questions
    By Avi Kwame in forum Technical Help
    Last Post: 04-09-2013, 07:06 PM
  3. Carb questions
    By RisingSun in forum Technical Help
    Last Post: 09-01-2011, 11:33 PM
  4. last round of carb questions
    By phazer in forum Technical Help
    Last Post: 08-06-2011, 05:44 AM
  5. more carb questions
    Last Post: 05-24-2011, 08:31 PM
